I finding the Thevenin equivalent resistance
SpiralStars
https://imgur.com/a/XD3Km4t
I'm trying to find the thevenin equivalent resistance across the opened terminals.
I know you short circuit the voltage source and do simple circuit analysis, however I'm getting confused in determining what resistors are parallel to each other and how to redraw the diagram once I simplified. How do I do this ?
My attempt got me 426.0.26 ohmz.
Please show us your work. It is much easier to check your answer if you show your work.
Hint: If there are no obvious resistances in parallel or in series that would allow you to reduce the circuit by simple methods then you should consider placing a voltage source at the "output" and solving for the current it would drive into the circuit; The problem then becomes one of general circuit analysis involving whatever methods you've learned. Once you know that current, then Ohm's law will tell you the resistance that the source sees.
The pictures are blurry but there's a approach that I always use.Lets suppose you started from one of the open terminals, let's say upper one. Also I didnt understand why you included ##100Ω## resistor.
In any case try to follow a current path in your mind. If the path divides two and you can't reach the B in 1 path then they must be parallel.
Second approach is that try to look the circuit from the open ends side but not from the normal image. I mean move the image 90 degrees right and try to look it that way. Also I think this is a homework question
You seem to think that R3 and R4 are in parallel, yes? If so, you might want to go back to the basic definitions of what is series and what is parallel.
I personally like solving for VOC and ISC when simplifying the circuit is not super obvious; you can use Ohm's law with those terms to reveal the RTH.
VOC = Output voltage with output as open circuit
ISC = Current going along the output node when it is short circuited to its reference ground.
