How Do You Calculate Average Speed with Variable Velocities and Accelerations?
To calculate the average speed of a particle with variable velocities and accelerations, first break the motion into segments: deceleration and acceleration phases. During the deceleration from 0.4 m/s to 0.2 m/s over 5 seconds, use the formula Vf - Vi = a*t to find the deceleration. For the acceleration phase of 0.2 m/s² over 4 seconds, apply the same principles to determine the distance traveled. The average speed is then calculated by finding the total distance covered in both phases and dividing it by the total time of 9 seconds. Understanding the relationship between velocity, acceleration, and distance is crucial for solving this problem correctly.
Haniszmi
A particle that is moving along a straight line decelerates uniformly from 0.4 m/s to 0.2 m/s in 5 seconds and then has a constant acceleration of 0.2 m/s^2 during the next 4 seconds. What is the average speed over the whole time interval?
vavg = (x - xo)/t
I first broke up the problem into two parts, first part being..."A particle that is moving along a straight line decelerates uniformly from 0.4 m/s to 0.2 m/s in 5 seconds"...I found the deceleration to be -.04m/s^2 by simple plugging into the formula. For the second part..."then has a constant acceleration of 0.2 m/s^2 during the next 4 seconds. What is the average speed over the whole time interval?" Since the acceleration was given to me in that statement I just added the deceleration and acceleration together and divided by two to get the average acceleration. DID I DO THIS CORRECTLY? MY ANSWER WAS .08m/s^2
You have the correct relevant equation -
vavg = (x - xo)/t
but in order to find the average speed, you need to find the distance traveled (which you can get from the accelerations and times given), and then divide the distance by the total time.
You can tell your original answer is wrong by checking the units of it - speed is m/s, acceleration is m/s^2 which are the units that adding the accelerations together would give you.
Ok I see where I had made my mistake, but now I am confused with how to find the distance traveled. How do you find the distance traveled if there are 2 different velocities?
In the deceleration phase you can determine that from the relation that
Vf - Vi = a*t
Then with that acceleration number you can figure distance with
Vf^2 - Vi^2 = 2 a (xf-xi)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
