I need serious help with this problem, it's about area and distance
  • Thread starter Thread starter afcwestwarrior
    Area
afcwestwarrior
by reading values from the given graph of f, use five rectangles to find a lower estimate and an upper estimate for the area under the given graph of from x=0 to x=10. in each case sketch the rectangles that you use.
since their are there are 5 rectangles, the width was 2 for each of them
and when i tried to figure out the lower and upper estimate i did this
L5= 2*O^2+ 2*2^2 ... 2 * 8^2 =128
and the answer in the back of the book is 40
and for Right end= 2*2^2 ... 2*10^2= 440
and the answer is 52
i already did sketched the rectangle thing, and it doesn't tell me what type of graph it is, it just tells me y= f(x)
The area of a rectangle is length*width. There is no 'square' in the formula.
ok, so then i don't have to square them,
i was looking at an example that was squaring them, no wonder, thanks man, i didn't think about the y= f(X)
ok so what do i do then
i didnt square the left end points and i got 40
but i did the same for the right end and i got 60
You must be able to determine the values of f(0), f(2) etc from your graph. Those are the heights. The widths are all 2.
how do i do that, what formula do i use
If you are going to get a numerical answer like 52 then you must be able to find f(0) etc. It's the y value of the graph when x=0 etc.
i did it, i multiplied 2 * the hieght, for every one
And got 52 for one of them?
yup, i got 53, but then i took a closer look at the heights and got 52
thanks for the help
