I think my answer should be right, but it isn't energy problem
  • Thread starter Thread starter holezch
    Energy
The discussion revolves around a physics problem involving a simple pendulum, specifically an inverted rod with a mass. The initial calculations for the speed at the lowest point were incorrect due to a misunderstanding of the height; the correct height is 2L, leading to the correct speed formula of v = 2sqrt(gL). For the tension in the suspension at the lowest point, it is clarified that the tension is not simply the negative weight but must account for centripetal acceleration, resulting in a tension of 5mg. The confusion stemmed from misinterpreting the forces acting on the mass during its motion. Understanding these dynamics is crucial for solving similar problems in mechanics.
holezch
A light rigid rod of length L has a mass m attached to its end, forming a simple pendulum. It is inverted and then released (I don't know what that's supposed to mean). What are:
a) the speed v at its lowest point
b) the tension T in the suspension at that instant
at the beginning, when it is dropped down, we should have K = 0 and U = mgL
at the bottom when it is finished dropping, we should have K = 1/2mv^2 U = 0
1/2 mv^2 = mgl
v = sqrt(2gL)
but the book says 2sqrt(gl)...
what did I do wrong?
thanks
I'm guessing "inverted" means the mass is a height L above the pivot point, so it's height above its lowest point is actually 2L rather than L
WOW. Thanks so much, I would never have known...
What about a "suspension"?
b) the tension T in the suspension at that instant..
Shouldn't it just be the negative weight? what answer book says 5mg.. :S
Thanks
Thanks
the 'tension T in the suspension at that instant' means 'what is the tension in the rod when the mass is suspended by the rod at the low point of its motion (that is, upon returning to its original position before it was inverted, but this time with a speed associated with it). This becomes a centripetal acceleration question, the tension is not the negative of the weight, because it is accelerating inwardly. The sum of forces in the y direction is not 0.
