I with the following questions.
  • Thread starter Thread starter DLxX
The discussion revolves around solving mathematical problems involving trigonometric equations and maximizing the area of a rectangle. For the first question, given csc(-) = 1.4, the participants suggest using a calculator to find possible values for (-) in radians. In the second question, they discuss solving equations like 2sin(3theta) = 1 and 2sin(-)cos(-) = sin(-), with hints provided on how to manipulate the equations. For the rectangle problem, the area is expressed as A = xy, and the constraint 3x + 2y = 96 is used to derive the dimensions, with a focus on using calculus for maximization rather than guesswork. The conversation emphasizes the importance of understanding the underlying mathematical principles rather than relying on trial and error.
DLxX
1. Given csc(-) = 1.4, what is one possible value of (-) in radians?
2. Solve for (-) in each equation. Give the exact value if possible. The domain is the set of all real numbers.
a) 2sin(3theta)=1 b) 2sin(-) cos(-) =sin(-)
(-) = theta btw
3. A rectange has a length of x and width of y. If 3x + 2y = 96, find the largest area the rectange can have and the dimensions of the largest rectange.
Mathematics news on Phys.org
3.It's rectangle (sic).Do you know how to use Lagrange multipliers...?
2 & 1.Post your work.
Daniel.
For 3 write the area in terms of x.
How do you maximize a function of one variable?
For number 3 I ended up getting x as 16 and y as 24, using guess and check. Is this correct?
U can't use guess and check.U need to use CALCULUS...
Daniel.
It may be the correct answer but it'd be better to learn a method, or a reason.
The above hints were one way. here's another.
you want to maximize xy subject to 3x+2y=96
that's the same as maximizing 2r*3s, letting 2r=x and 3y=s, subject to
r+s=16, which by symmetry always happens when r=s=8 so x=16 and y=24 indeed.
1. How is csc defined? After you have answered that, use a calculator.
2. a) Divide both sides of the equation by 2: sin(3θ)= 1/2 You should be able to write 3θ immediately - if not use a calculator.
b) An obvious possibility is sin(θ)= 0. If sin(θ) is not 0, you can divide the equation by sin(θ) to get 2cos(θ)= 1 so cos(θ)= 1/2 .
Now see part (a)!
3. The area of a rectangle with sides x and y is A= xy. You are told 3x+ 2y= 96 so
y= 48- (3/2)x. A= x(48- (3/2)x)= 48x- (3/2)x2. You can now complete the square to find the largest possible value of that.
Daniel.
I'm in Grade 12 Pre Calculus and this assignment isn't based on new material, but material most likely learned in Grade 11 Pre Calculus, so I doubt I have to use Calculus. Unless the Calculus needed is very basic.
2. a) Divide both sides of the equation by 2: sin(3?)= 1/2 You should be able to write 3? immediately - if not use a calculator.
b) An obvious possibility is sin(?)= 0. If sin(?) is not 0, you can divide the equation by sin(?) to get 2cos(?)= 1 so cos(?)= 1/2 .
Now see part (a)!
For number 2a) I got 9.6 and 170.4 degrees. and for 2b) I got 60 and 300 degrees. Is this correct?
