Ice cores suggest methane spike may be caused by plants, not hydrates
A study published in Science indicates that a significant increase in atmospheric methane around 12,000 years ago was likely due to emissions from tropical wetlands or plant production, rather than from seafloor methane hydrates. Researchers analyzed carbon isotopes from Greenland ice cores, concluding that the isotopic signature of the methane did not align with that expected from hydrate releases. This finding challenges previous theories linking methane spikes to rapid global warming events at the end of the last ice age. The study highlights the need to reassess current estimates of methane emissions, including human contributions, and raises concerns about methane release from melting permafrost. Understanding these sources is crucial as methane is a potent greenhouse gas, second only to carbon dioxide.
Mk
http://www.eurekalert.org/pub_releases/2006-08/osu-sro082106.php
A dramatic increase about 12,000 years ago in levels of atmospheric methane, a potent greenhouse gas, was most likely caused by higher emissions from tropical wetlands or from plant production, rather than a release from seafloor methane deposits, a new study concludes.
This research, to be published Friday in the journal Science, contradicts some suggestions that the sudden release of massive amounts of methane frozen in seafloor deposits may have been responsible – or at least added to - some past periods of rapid global warming, including one at the end of the last ice age.
The findings were made with analysis of carbon isotopes from methane frozen in Greenland ice core samples, by researchers from Oregon State University, the University of Victoria, University of Colorado, and the Scripps Institution of Oceanography at the University of California-San Diego.
For climate researchers, an understanding of methane behavior is of some significance because it is the second most important "greenhouse gas" after carbon dioxide. Its atmospheric concentration has increased about 250 percent in the last 250 years, and it continues to rise about 1 percent a year.
...researchers studied two stable isotopes of carbon found in methane, that can provide a better idea of where the methane came from during a period thousands of years ago when Earth was emerging from its most recent ice age, and entering the interglacial period that it is still in. At that time, methane concentration went up 50 percent in less than 200 years.
"There have been estimates that releasing even 1 percent of the methane hydrates in the seafloor could double the atmospheric concentration of methane," said Ed Brook, an associate professor of geosciences at OSU and co-author on the study. "So we looked to the past to see if that may have happened during previous periods of rapid global warming."
Based on their isotopic analysis of the methane from the Greenland ice cores, the researchers concluded that it did not come from seafloor hydrate deposits or "gas bursts" of methane associated with them. The most likely candidates, they said, were higher emissions from tropical wetlands or larger amounts of plants, or some other combination of sources.
If the rise in methane had come from seafloor hydrate deposits, the study found, the atmospheric levels of methane would have had a different isotopic "signature" than they actually did.
...The current understanding of methane sources and sinks does not completely explain the isotopic signature of methane now found in the atmosphere. This indicates that estimates of methane emissions, including the human-made contribution, may have to be revised.
There are also concerns, they said, about methane trapped in permafrost across wide areas of the Earth's Arctic regions. There are significant amounts of methane found in this permafrost that could be released if it melted, and also organic material associated with melting permafrost that could cause further increases in methane. This might cause "a fairly significant rise in the total level of atmospheric methane of around 20 percent," Schaefer said.
Isn't that curious. Well here is the abstract.
Hinrich Schaefer, Michael J. Whiticar, Edward J. Brook, Vasilii V. Petrenko, Dominic F. Ferretti, Jeffrey P. Severinghaus 2006 Ice Record of 13C for Atmospheric CH4 Across the Younger Dryas-Preboreal Transition, Science 25 August 2006: Vol. 313. no. 5790, pp. 1109 - 1112
We report atmospheric methane carbon isotope ratios (13CH4) from the Western Greenland ice margin spanning the Younger Dryas–to–Preboreal (YD-PB) transition. Over the recorded 800 years, 13CH4 was around –46 per mil (); that is, 1 higher than in the modern atmosphere and 5.5 higher than would be expected from budgets without 13C-rich anthropogenic emissions. This requires higher natural 13C-rich emissions or stronger sink fractionation than conventionally assumed. Constant 13CH4 during the rise in methane concentration at the YD-PB transition is consistent with additional emissions from tropical wetlands, or aerobic plant CH4 production, or with a multisource scenario. A marine clathrate source is unlikely.
However there is something fishy here and I'll explain later
The fishy thing is here, of the last author, Jeff Severinghaus. http://icebubbles.ucsd.edu/pubs.html is the most interesting.
Check:
Here we address these problems with measurements of isotopes of nitrogen and argon gas trapped in air bubbles in the GISP2 (Greenland Ice Sheet Project 2) ice core. Bubble 15N/14N and 40Ar/36Ar record a signal of rapid temperature change at the surface of the ice sheet
The idea is that temp changes change fractionation processes with heavy isotopes within the firn, causing an enrichment during the warming. Isotopes, that is, all the gas isotopes, isn't it? Seeing this http://www.sciencemag.org/cgi/content/abstract/313/5790/1109 (anybody seen the complete study?) it does not appear that they corrected for this gravitational and molecular fractionation of the CH4 gas, did they?
If indeed they did not, then the corrected 'warming' isotope ratio should be a lot lower, right?
Here it is. http://static.mwnx.net/mac/Climatology/Ice%20record.pdf
Testing Just lost a post worth of an hour work. :mad:
Well here are the links
http://www.ig.uit.no/~maarten/publications/Buenz_etal_Geophysics_2005.pdf
http://www.sciencemag.org/cgi/content/abstract/311/5762/838
http://www.ig.uit.no/~maarten/publications/Mienert_Vanneste_etal_MPG_2005.pdf
http://www.sciencemag.org/cgi/data/313/5790/1109/DC1/1
Bottom line was that Sowers and Schaefer et al see appear to see considerable differences in atmospheric oxidation and that the Clathrate methane source of the Preboreal, the Ormen Lange gas field was geologic methane not biogenic methane, with a different isotope signature.
It hasn't happened to me for a while because I put a lot of saftey procautions on my browser, but I used to save long posts on notepad so I would still have them and laugh in the face of my computer when my window closed or something.
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
We have little shade but plenty of wind on my property. The upshot of this is that I have to be judicious in how/where I put up shade-creating barriers in various places around my property to maximise shade without unduly large windage. My property is an irregular polygon and not aligned with the cardinal axes, so it is not easy to tell where the shade will be at a given time. For example, I have put up an umbrella next to our pool, but it can only shade the southish-side of the pool, and...
These last days, there is a seemingly endless cluster of rather powerful earthquakes close to the islands of Santorini, Amorgos, Anafi, and Ios. Remember, this is a highly volcanically active region, Santorini especially being famous for the supervolcanic eruption which is conjectured to have led to the decline of the Minoan civilization: https://en.m.wikipedia.org/wiki/Minoan_eruption To grasp the scale of what is happening, between the 26th of January and the 9th of February, 12000...
