How to Calculate Pressure Difference in Aorta with Ideal Fluid Model
  • Thread starter Thread starter Rron
    Fluid
To calculate the pressure difference in the aorta due to an aneurysm, apply the principle of conservation of mass, which states that a1v1 = a2v2, where A2 is 1.7 times A1. Given the average blood density of 1060 kg/m3, the velocities are v1 = 0.40 m/s in the normal section and v2 = 0.24 m/s in the enlarged section. Bernoulli's equation is essential for deriving the pressure difference, as it relates pressure, velocity, and height in fluid dynamics. The discussion emphasizes the importance of these equations in solving the problem effectively. Understanding these concepts is crucial for accurately determining the pressure in the aorta.
Rron
An aneurysm is an abnormal enlargement of a blood vessel such as the aorta.
Suppose that, because of an aneurysm, the cross-sectional area A1 of the aorta
increases to a value A2 = 1,7A1. The speed of blood, with average density of
1060 kg/m3, through a normal portion of the aorta is v1 = 0,40 m/s, and through
the enlarged region is v2 = 0,24 m/s. Using the model of an ideal fluid and
assuming that aorta is horizontal (the person is lying down), determine the
amount by which the pressure P2 in the enlarged region exceeds the pressure
P1 in the normal region!
a1v1=a2v2
a=surface
v=velocity
The only thing is how to get an equation for pressure from this a1v1=a2v2
I guess
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
