Ideal Gas Situation: What happens when P, V decrease?
When the volume and pressure of an ideal gas decrease, the temperature also decreases, leading to a reduction in internal energy. The internal energy is directly related to kinetic energy, which decreases as temperature drops. Intermolecular forces remain unchanged and are effectively zero in an ideal gas scenario. The initial confusion about the relationships between internal energy, temperature, and kinetic energy was clarified, confirming that a decrease in temperature results in a decrease in internal energy. The final understanding aligns with the principles governing ideal gases, resolving the initial errors in reasoning.
yaylee
If the volume V and pressure P of an ideal gas decrease, which statement is true about the internal energy IE, temperature T and the intermolecular forces IF?
(I am not going to copy and paste the choices here in an effort to focus attention on the attempt of solution.) Would greatly appreciate if anyone can point out an error in thinking!
Change in Internal Energy (I.E.) = Q (heat added) + W (done on system)
PV/T = PV/T
First: My final answer. (Incorrect)
IE increases, T increases, IF are unchanged
Since P and V decrease, by P1V1/T1 = P2V2/T2, the temperature of this ideal gas should decrease.
Since Kinetic Energy is directly proportional to KE, the Internal Energy of the system should increase!
(In an ideal gas: no Intermolecular forces, otherwise, the gas would liquefy!)
So, Internal Energy is composed of KE, and since Temperature goes up, IE goes up, and IF is constant (or zero).
Many thanks in advance !
Welcome to PF, yaylee! :smile:
PV/T = PV/T
That is correct: the temperature decreases.
Huh? I'm assuming the with KE you mean Kinetic Energy, don't you?
This doesn't make sense to me.
Either way, the Kinetic Energy is directory proportional to the Internal Energy.
And they are both also directly proportional to the temperature.
So since temperature goes down, so do KE and IE.
It's not true that the gas would liquify - that would depend on the circumstances.
But yes, in an ideal gas there are no intermolecular forces.
Hold on!
Didn't you say before that the temperature decreased? :confused:
Btw, you are right that IF is constant, moreover it is and remains zero, since we're talking about an ideal gas.
Hello I like Serena !
Thank you for the welcome.
I am sorry for mixing up increase/decrease throughout the problem.
In an ideal gas, As temperature DECREASES, Kinetic Energy decreases and therefore internal energy DECREASES.
Also: Intermolecular forces are unchanged, or remain zero throughout.
I am wondering why this is getting marked incorrect, oh well! Thank you once again.
Ah, OK. There was a mistake with the scoring. Your answer was correct. Thanks for the help!
As you just wrote it down, it is correct.
Cheers!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
