What is the boiling temperature of the liquid?
The boiling temperature of the liquid is estimated to be approximately 382.424 K based on pressure readings from a constant volume gas thermometer. The recorded pressures at the Triple Point of water were 0.500 atm and 0.250 atm, with corresponding pressures of the boiling liquid at 0.720 atm and 0.350 atm. The Ideal-gas Temperature Scale equation, T = 273.16 lim Ptp->0 (P/Ptp), indicates that using the lower pressure value for Ptp yields a more accurate temperature measurement. Therefore, the lower pressure values should be prioritized for calculations.
  • Understanding of the Ideal-gas Temperature Scale
  • Knowledge of gas thermometers and their operation
  • Familiarity with pressure measurements in thermodynamic contexts
  • Basic grasp of the concept of the Triple Point of water
  • Study the Ideal-gas law and its applications in thermodynamics
  • Learn about the significance of the Triple Point in thermodynamic measurements
  • Explore the principles of constant volume gas thermometers
  • Investigate methods for accurately measuring boiling points of liquids
Students in physics or chemistry, educators teaching thermodynamics, and researchers involved in temperature measurement techniques will benefit from this discussion.
henryc09
the gas scale temperature is defined as:
T=273.16 lim Ptp->0 (P/Ptp)
The bulb of a constant volume gas thermometer is immersed in an ice-water-vapour mixture and the recorded pressure is 0.500 atm. It is then immersed in a boilng liquid and the pressure is 0.720 atm. Some gas is removed from the bulb and the experiment repeated, registering 0.250 and 0.350 atm respectively. Estimate, as accurately as possible, the boiling temperature of the liquid. [2]
So here Ptp is recorded as 0.5 and 0.25, with corresponding P's of 0.72 and 0.35 right? Would it be better to take the average value calculated or use only the lower value of Ptp as it closer to 0? I'm a bit confused.
The boiling temperature of the liquid is approximately 382.424 K.
You have to understand what the Ideal-gas Temperature Scale actually means.
T = T_{TP} \lim_{P_{TP}\to\ 0} (\frac{P}{P_{TP}})
The above equation, states that the temperature of the substance which you are measuring (in this case the boiling liquid) is given by a function of the Triple Point of water (273.16 K) times the ratio of the pressure of this boiling liquid by the pressure of the Triple Point of water. The limit is used to show that as the Triple Point pressure goes to zero, the more accurate will be the temperature to be measured.
Therefore, you will work with the lowest measures provided. As the more accurate temperature will be given as P_{TP} \rightarrow 0.
  • · Replies 21 ·
  • · Replies 29 ·
