s.p.q.r
- 25
If a sample of air had high pressure and high temperature, would it be a real or ideal gas?
A real gas is a gas that does not strictly follow the ideal gas law, which relates the pressure, volume, and temperature of a gas. An ideal gas is a hypothetical gas that follows the ideal gas law exactly.
For real gases, as pressure increases, the volume of the gas decreases, which is known as the compressibility of the gas. As temperature increases, the average kinetic energy of the gas particles increases, causing them to move faster and increase the pressure.
Real gases deviate from ideal gas behavior due to intermolecular forces between gas particles, finite molecular size, and non-uniformity of gas particles. These factors cause real gases to have slightly different properties than predicted by the ideal gas law.
The ideal gas law, PV = nRT, takes into account the pressure and temperature effects on gases by including the variables of pressure (P) and temperature (T). These variables determine the volume (V) of the gas, as well as the amount of gas (n) and the gas constant (R).
In certain conditions, real gases can behave like ideal gases. This usually occurs at low pressures and high temperatures when the effects of intermolecular forces and molecular size are minimal. Under these conditions, the properties of real gases closely resemble those of ideal gases.
