Identify this electrical component or device
32 replies · 4K views · last reply
giokrutoi
I have no idea what is this
  • Photo of a small electric motor with a laminated metal stator and wound copper coils, a brass commutator at the centre, and an aluminium end housing with two mounting bosses, resting on a wooden surface.
Nothing to show scale, nothing to show normal orientation, not a very elucidating viewing angle.
My first thought was a piece of surveying equipment.
A motor of some sort. I see field laminations, a commutator and brushes. I see what is most likely a fan on the right side. Looks like maybe the guts for a handheld electric mixer.
  • Photo of a disassembled universal motor showing a laminated iron stator with copper winding, a commutator with carbon brushes, an aluminium end bracket and a white plastic fan.
  • Photo of an opened universal motor with a laminated iron stator, copper windings, a commutator and brushes, a red capacitor, and a worm gear at the end of the shaft.
here is another picture
  • Photo of an opened universal motor on a wooden surface, showing a laminated stator with copper field windings, a central armature with commutator, a metal end bracket with bearing housings, a plastic fan at one end, and a red capacitor.
That worm gear will drive two gears sitting in those encasements in opposite directions, surely attached to shafts. So, two shafts, just a few inches apart driving in opposite directions.
I say it's the motor for an ancient clothing wringer. Otherwise known as a child-hand-and-arm-flattener.
Vintage white wringer washing machine with a round tub, a black central agitator, and a hinged top wringer with rollers, beside a white motor housing with a cord.
Averagesupernova said:
They will spin too fast for any clothing wringer I have been around.
Valid point. I don't see any gearbox that would reduce revs, but I won't rule it out.
Mixer is good too.
mixer may be but I think it may be part of tv
can it be so?
No way. There are no heavy-duty, mechanical, moving components in a TV of any decade.
That is most definitely a heavy-duty motor driving two shafts in opposite directions in close proximity.
Well, in an industrial mixer. I think Average is correct.
If you wish to re-use it, you could take the head off, and you'd have a powerful electric motor for something. Don't know what the revs are.
A bit off topic but the old wringer washers had a shaft that run up through the pedestal that the wringer part mounted on. There was only one motor and it was underneath. Just gearing to get the power up to the wringer rollers.
Just curious, why would you have thought surveying equipment? What made your mind go there?
I love making new from old stuff that's all
Pretty sure this was directed at me. :wink:
I didn't get a good look at the motor part until you pointed it out in the follow-up pix. My first look saw two circles about the size - and separation - of eyes, on a tall, tripod-like stock.
I like the mixer idea. The spinning plastic part could (with gearing) spin a bowl. The fins could engage for different gear ratios.
Clearly it should be Aboveaveragesupernova. :partytime:
Well I used to be Superaveragenova but I decided I would rather be averagely super. o0) LOL
Strangely I don't recall how I really came up with the name. It just popped in my head. It is interesting to me in that it doesn't seem possible for an event like an exploding star to be 'average' and boring, but of course everything is relative and there are in fact actual average supernovas.
I figure that's really more of the cooling mechanism for the motor.
The two different drives taken from the motor suggest a low speed, reversible, high torque drive at one end (as people have already said) and a high speed takeoff dog on the other end - could be a pump drive (not much torque transferred through that plastic piece but a pump wouldn't need it). Most washing machines would have two separate motors, in my experience, but an old design could have used just one. I'd love to see the controller / timer for it.
@Dave - you really are too, too good to your partner. Buying her all the latest white goods, as in the photo.
giokrutoi said:
and how can I make it work
Try to find a part number on the motor somewhere. from that you might be able to cross reference the equipment manufacturer.
Shop garage sales and junk yards for old parts that might fix. Then design what you need to fill in the missing bits. There are websites that will do 3-D printing to order.
I was thinking universal motor from a Vacuum Cleaner, but Mixer may be correct.
I must have missed something.
When you say "two different drives", do you mean two drive shafts, one out each end?
And how do you figure one is low speed and the other is high-speed?
If there were a gearbox in there, that would lend credence to my suggestion of it being a low-speed wringer-dryer.
There is a worm gear on the left and a straight 'dog' on the other end; could be a 10:1 difference in final speeds of the two drives.
I think the worm that you can see is all that's left of the low speed gearbox, with the two pinions missing. That could provide two directions for rotating some heavyish load.
o:) Of course. I wasn't even thinking of the worm gear as a reducer.
