Identity for the probability of a coin having an even number of heads
koab1mjr
Given that n independent tosses having probability of p of coming up heads are made, show that an even number of heads results is 0.5(1+(q-p)^n) where q is 1-p, by proving the identity
Sigma from i=0 to n/2 of (n choose 2i) (p^2i)(q^(n-2i))=0.5(((p+q)^n)+(q-p)^n)
I expanded it, (n choose 0)p^0 q^n + (n choose 2)p^2 q^(n-2)+...letting i=n/2 we get (n choose n)p^n q (n-n) ends up being just p^n.
Hi koab1mjr! :smile:
(have a sigma: ∑ and try using the X2 and X2 tags just above the Reply box :wink:)
Hint: start at the end …
what is the coefficient of pjqn-j of 0.5(((p+q)n)+(q-p)n) for j even? and for j odd? :wink:
thanks, but...
I tried it, but i am still not getting it, because starting from the end for even, i got p^2q^(n-2), p^4q^(n-4) and so on, plus i cannot get the factorials to work out...
(just got up :zzz: …)
koab1mjr said:
…for even, i got p^2q^(n-2), p^4q^(n-4) and so on …
(please use the X2 tag just above the Reply box)
p2qn-2 time what? p4qn-4 times what? … p2jqn-2j times what?
Couldn't resist: The probability of a coin having an even number of heads should be zero.:smile:
timing each one by (n choose 2), (n choose 4), and so on until i hits n/2, and at that point all becomes just p^n
Hi koab1mjr! :smile
(you can write that nC2 etc :wink:)
Yup! :smile:
And that's exactly the left-hand-side of the original identity, isn't it? :wink:
yeah, when you plug in i=n/2 on the he left side you get p^n, but when you expand the right side and at the end you do the exact same thing, but the problem is that the identity of (1/2)[(p+q)^n + (q-p)^n) doesn't show up at all??
koab1mjr said:
… the problem is that the identity of (1/2)[(p+q)^n + (q-p)^n) doesn't show up at all??
Sorry, I'm not following you at all. :redface:
Hi Tiny Tim
I finally got it. I applied Newton's bionomial expansion to prove the identity. Thank you so much for your help. IT help get me thinking in the right direction. You are the best.
