If f(x+a) = f(x-a) where a is infinitesimally small then....
  • Context: Graduate
  • Thread starter Thread starter Ahmad Kishki
The discussion revolves around the implications of the equation f(x+a) = f(x-a) where 'a' is infinitesimally small. Participants explore whether this leads to the conclusion that the derivative f'(X) equals zero, examining the conditions under which this might hold true. The conversation includes theoretical considerations and mathematical reasoning.
  • Some participants assert that if f(x+a) = f(x-a), then f'(X) must equal zero, arguing that this follows from differentiating a constant with respect to a variable.
  • Others challenge this conclusion, stating that inserting the infinitesimal 'a' into the derivative is inappropriate, as 'a' is part of the limit process in differentiation.
  • A participant questions whether the equation holds for all x and all infinitesimals a, suggesting that the result may not be universally applicable.
  • Some participants provide counterexamples, such as f(x) = |x| and f(x) = sin(x)/x, to illustrate that the conclusion does not necessarily follow in all cases.
  • There is discussion about the notation used for derivatives, with some suggesting that the notation df(a)/dx can lead to confusion regarding its interpretation.
  • A later reply indicates that if f is differentiable at X, then the claim could be true, but emphasizes that this depends on the function's properties.
  • One participant reflects on a friend's example using f(x) = x^2, arguing that the derivative at a specific point does not yield zero, despite the function appearing symmetric around that point.
  • Another participant elaborates on the calculations involving f(2-a) and f(2+a) to demonstrate that there is indeed a non-zero difference between them, raising questions about the interpretation of derivatives in this context.
Participants express differing views on whether the conclusion that f'(X) = 0 follows from the initial condition. There is no consensus, as some argue in favor of the conclusion while others provide counterexamples and challenge the assumptions involved.
Limitations include the dependence on the specific function being analyzed and the potential ambiguity in the notation used for derivatives. The discussion also highlights the need for clarity regarding the conditions under which the initial equation holds.
Ahmad Kishki
if f(X+a) = f(X-a) where 'a' is infinitesimally small then does the result f'(X) = 0 follow?
X is a point along the x axis.. Sorry about the fault in the question
Yes it does. You're differentiating a constant with respect to a variable, which will always be 0 no matter how small or large the constant is.
to be sure df(a)/dx means find df(x)/dx then input x=a
No. Why would you insert the infinitesimal a in the derivative? It is part of the limit in taking the derivative. It is the derivative at x which is zero.
Ahmad Kishki said:
if f(x+a) = f(x-a) where 'a' is infinitesimally small then does the result df(a)/dx = 0 follow?
Does ##f(x+a) = f(x-a)## hold for all ##x##? For all infinitesimals ##a##?
Not necessarily. Unless perhaps if the equation in the OP holds for all ##x##.
Is that really the question you intended to ask? PWiz's point is that f(a) for any specific number a is a constant so its derivative is 0. I suspect that you intended to ask "if f(x_0- a)= f(x_0+ a), for any infinitesimal a, is df/dx, at x= x_0, equal to 0?"
Though I will point out that "df(a)/dx" is a common short form for "df/dx evaluated at x= a" so I think he is stretching the point a little! However, since it is "a" that you are taking to be infinitesimal, you certainly don't what to say "df/dx evaluated at x= a" either.
i just realized that my effort to ditch writing the question in latex resulted in a problem... i will edit the question for it to make sense.. Sorry about that.. I meant with x as just some point not the variable.
if f(X+a) = f(X-a) where 'a' is infinitesimally small then does the result df(X)/dx = 0 follow?
Well, to be perfectly frank, the OP is mixing a lot of things.
Assuming that ##f(x+a) = f(x-a)## holds for every infinitesimal, then the answer is no. Take ##f(x) = |x|## at ##X=0##.
Yeah really sorry about that :/
I strongly suggest that you do not use the notation df(X)/dx to mean the derivative of f wrt x evaluated at X. The more common interpretation would be the derivative of f(X) wrt x, which is zero regardless of x. What was wrong with f'(X)?
Not necessarily. For example, let the function ##f(x)## equal ##\frac {sin x}{x}## . Then for "X" = 0 , you'll approach the same function output as ##a## tends to 0 satisfying the first condition, but the function at "X" will be undefined.
If you assume ##f## differentiable at ##X##, then the answer is true. Indeed, the Newton quotient for an arbitrary infinitesimal ##a## is
[tex]\frac{f(X+a) - f(X)}{a} = \frac{f(X+(-a)) - f(X)}{a}[/tex]
Taking standard part of left and right hand sides yields (since the function is differentiable at ##X##):
[tex]f^\prime(X) = - f^\prime(X)[/tex]
which gives us the result.
PWiz said:
Not necessarily. For example, let the function ##f(x)## equal ##\frac {sin x}{x}## . Then for "X" = 0 , you'll approach the same value function output as ##a## tends to 0 satisfying the first condition, but the function at "X" will be undefined.
This function has a well defined limit and can easily be extended to a continuous and differentiable function at x = 0.
micromass said:
[tex]\frac{f(X+a) - f(X)}{a} = \frac{f(X+a) - f(X - a)}{a} + \frac{f(X-a) - f(X)}{a} = -\frac{f(X+(-a)) - f(X)}{a}[/tex]
Sign error in the last step, but the later conclusion is correct. As it stands, the right hand side would evaluate to f'(X).
The OP didn't specify the function domain, so I took the liberty of using natural domains.
No. It only means that the function is continuous in x.
No it doesn't.
No it does not. Consider the function f(x) = 0 if x ≠ 0 and f(0) = 1.
Check corrected question... Its a question that i wrote down with a + epsilon, and since i wanted to avoid latex, it got me confused... In short, check the corrected question... Sorry about that
Thank you all for the answes provided. The answer to the question is that the claim is true if f'(X) exists.
Follow up:
I was talkig about this with a friend and he told me that he suspects if this is true and gave me an example of f(x) = x^2 and said f(x-a) = f(x+a) for say x=2 when a is infinitesimally small, but the derivative of x^2 at x=2 is obviously not zero. I answered him by saying that f(x+a) is in fact not equal to f(x-a) they must differ by a small distance delta such that delta/2a is equivalent to the derivative at the point in question. I am not very solid with the epsilon-delta definition so is this the right way to answer this?
##f(2 -a ) = (2 - a)^2 = 4 - 2a + a^2## and ##f(2+a) = (2+a)^2 = 4 + 2a + a^2##. Hence ##f(2-a) - f(2+a) = -4a##. This is not zero, so there is indeed an infinitesimal distance between them.
Interesting point: i would expect 4a/2a=2 to be the derivative of x^2 at x=2 but this isn't the case the derivative is 4 not 2, so what does this 2 mean and why don't we get the derivative?
(Since the deivative is f(2+a) - f(2-a) = 2a * f'(2) leading to 4a/2a = 2)
What went wrong?
This is mathematical pettifoggery. But yes, the case a=0 was excluded by speaking of "a" as "infinitesimally small".
Everybody except a mathematician or a pocket calculator knows that sin(x)/x=1. ;-)
Yes, but that is besides the point.
If the domain is not carefully specified, then the value remains undefined "at" x=0 as the natural domain of the function is then considered.
Even if ##a = 0##, the quoted function satisfies the requirement ##f(x+a) = f(x-a)## at ##x = 0## (in fact, it is satisfied for all ##a##, be it finite, infinitesimal, or zero).
For ##a = 0##, any function will satisfy the relation, regardless of whether the function is continuous or not.
This is a mathematics subforum after all. There was one statement in your post and it was not a logical conclusion from the given fact. I think it is worth pointing this out in order not to confuse the OP.
It is always true for a function that is continuous around x. You can not say that if it is discontinuous. But sure, you may find examples of discontinuous functions where it also holds.
  • · Replies 31 ·
  • · Replies 24 ·
  • · Replies 43 ·
