If light cannot bend, then how magnify glass works?
  • Context: High School
  • Thread starter Thread starter Ganesh Ujwal
    Bend Glass Light Works
The discussion centers on the principles of light behavior, specifically refraction and reflection, and how they relate to magnifying glasses. Participants clarify that light does bend due to changes in speed when transitioning between different media, as explained by Maxwell's equations. The analogy of vehicles transitioning from smooth to rough roads is used to illustrate how light behaves at the interface of different materials. The conversation concludes that refraction and reflection are well-understood phenomena, not mysteries, and are governed by the wave nature of light.
  • Understanding of Maxwell's equations
  • Basic knowledge of wave behavior in physics
  • Familiarity with the concept of refractive index
  • Knowledge of light as an electromagnetic wave
  • Study Maxwell's equations in detail
  • Research the concept of refractive index and its applications
  • Explore wave-particle duality in light behavior
  • Learn about the principles of lens design and optics
Physics students, optical engineers, educators, and anyone interested in understanding the fundamental principles of light behavior and optics.
Ganesh Ujwal
i don't understand if light cannot bend, then how magnify glass works?
how it is bending & magnifying the light?
Science news on Phys.org
Google refraction.
if light cannot bend then how refraction & reflection of light are working?
is it still mystery or any other theory is there for this?
There is nothing "mysterious" about it at all. GOOGLE REFRACTION and read the whole thing.
i am asking if light can not bend, how REFRACTION is done ?
Who says a ray of light does not bend?
how medium can bend the light?
water is bending the light everytime. is it mystery?
It is not a mystery. Refraction is caused by a change in the speed of light at the interface of two different transparent media.
if we throw the ball it will bounce, when it touches the ground, so same way, the light bounces back that bounce of light is called refraction, am i right?
That is reflection. Reflection and refraction are different.
If you want a mechanical analog of refraction think of a vehicle which rolls at an oblique angle from a smooth road onto a rough road.
think of a vehicle which rolls at an oblique angle: means vehicle going down mountain slope down, then it will go fast, because slope down will increase the velocity of vehicle. same way refraction will increase the speed of light ray like speed of vehicle increased by mountain slope through mechanical analogy.
Forget the slope of the mountain, consider the road to be level. What happens when a vehicle rolls from a smooth road onto a rough road?
of course any two wheeler or four wheeler vehicle will get spoiled, due to rough end due to heavy friction. sorry, but it doesn't explains about light.As you said it will bend due to different medium, wiki is showing light bend due to surface phenomenon, i am confused. so light bends because of two reasons: surface phenomenon & different medium? what i understand about light bend is right or wrong?
OK, now, before it gets spoiled, will it travel straight or will it tend to turn one direction or the other?
Of course it doesn't explain, it is an analogy, not an explanation. The explanation is Maxwells equations.
will it travel straight or will it tend to turn one direction or the other? it depends on driver's experience. of course anybody can change vehicle direction due to steering. it works under steering gear mechanism. but light is electromagnetic waves. it carries energy every time.
vehicle direction is depends on driver mindset.
so due to Maxwells equations, light is bending & bounces back?
No. The tendency of the vehicle is a matter of physics. An experienced driver can compensate for what the vehicle tends to do, but that does not change the physics.
Again, what does the vehicle tend to do?
It seems like you have left for the time being, and in an hour or so I will have to also, so I will answer my own question and then give an explanation from Maxwells equations.
If there is rough road to the right and a vehicle goes from smooth road onto the rough road then it will tend to pull to the right. This will happen as soon as the right tire hits the rough road and is slowed down compared to the left tire which is still going on the smooth road. Analogously, light will turn if it goes into a medium with a slow speed of light (analogous to the rough road).
One of the simplest solutions to Maxwells equations is a single frequency plane wave. If you take two such solutions, one for each material, and match them at the interface, then you will get that the propagation direction is different in each.
thank you it explains lot, but what i understand is there is no theory to explain or demonstrate why light refraction & reflection.
I already told you that the theory is Maxwells equations.
Let's do away with analogies here, I don't think they will help. Light is NOT a ray that travels in a straight line. It is an electromagnetic wave. A ray is a simplification that makes it easier to calculate what the light will do in certain situations, such as what happens when it enters a lens or hits a mirror.
Refraction is a property that all types of waves have. When a wave enters a medium where the speed of the wave is different, it changes direction unless it enters the new medium straight on at a 90 degree angle. The reason why this happens is hard to grasp but has to do with how different parts of the wave interfere with each other while the wave moves across the boundary.
I have no idea why you believe this. It is utterly wrong. Refraction and reflection are understood extremely well.
It may be helpful to recognize that a light beam is not zero width. It is not a one dimensional line intersecting the surface.
The light beam has a width it is a wavefront, and parts of it reach - and interact with - the surface at different times. So, one edge of the light beam slows down passing through the medium before the other.
There's more to it..
pardon me, i am not asking light has width,dimensions or not.
Yes, Dave completely understands that you were not asking that, he was giving you another helpful way to see what is happening. You really seem determined to not understand that refraction is no big mystery.
You are asking how it refracts.
In the car/road analogy, the car will veer off the road in essence because the car is non-zero width, meaning the two front tires hit the mud at different times. A motorcycle, being essentially one dimensional, has only one front wheel to hit the mud, so no delay.
The car/road analogy breaks down quickly, but maybe it will get the idea across.
And it continues out the other side, both wheels in dirt to right wheel back on pavement pulls back to the direction the car was traveling offset by the distance thru the refractive medium. That's for straight lanes, like flat glass. Lenses as you might guess change the angle your wheels hit dirt.
Ganesh Ujwal said:
is it mystery
I wonder if he's having trouble with the notion that the speed of light isn't constant as is often thought. If so:
It is not a mystery. A photon hits an atom. The atom absorbs it and emits an identical one in a different direction. It's not the same light that you started with. The individual photons still travel at c (group velocity), so relativity isn't questioned, but they are absorbed/emitted at a slower rate (phase velocity). The rate at which these interactions occur is the speed of the phase velocity, and is referred to as the "refractive index".
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 77 ·
