If something moves fast it gains temperature?
Temperature is defined as the average kinetic energy of particles, measured in a frame where the system is at rest. Observing a moving particle system from a different frame does not yield a higher temperature because the additional kinetic energy from the motion of the frame is not included in the temperature calculation. The concept of temperature is better understood through statistical mechanics, which relates energy changes to the number of available microstates. Consequently, the Doppler effect observed in emitted radiation does not affect the intrinsic temperature of the system. Understanding these principles clarifies why temperature remains consistent across different frames of reference.
physics user1
Temperature is the average of the kinetic energy of the particles, if the bunch of particle moves fast and you look at the particles in two differece frame of reference, on steady with the bunch of particles and the other not, in the last one you get an higher temperature of the bunch of particle? If not why?
And again, since a body emits electromagnetic radiation at a certain temperature, if you see that body in different frame of reference you should get a doppler effect right? So if you attend to measure the temperature considering the light emmited you get different values?
Science news on Phys.org
It is the average kinetic energy of the individual particles using a frame in which the system whose temperature is being measured is at rest. Thus
if the bunch of particle moves fast and you look at the particles in two different frames of reference, oen steady with the bunch of particles and the other not, in the last one you get an higher temperature of the bunch of particle? If not why
You do not, because the the "extra" kinetic energy from choosing a frame in which the system as a whole is moving does not count towards the calculation of the temperature.
This will look much less arbitrary and will make more sense if you learn the definition of temperature from statistical mechanics, where the temperature is calculated from the relationship between the change of energy of a system and the number of microstates available to it. The "average kinetic energy" understanding of temperature is derived from this calculation.
Likes physics user1
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
9K
9K
11K
