If space is expanding how can the electrical properties stay constant?
The discussion centers on the implications of an expanding universe on the constancy of fundamental physical constants, particularly the fine structure constant. It is suggested that the fine structure constant, which depends on electrical charge, the speed of light, Planck's constant, and the permittivity of space, may not be constant over time. Experimental data indicates that one or more of these constants could change, potentially leading to variations in the permittivity of space. This raises questions about the constancy of the speed of light, with some Australian experiments proposing that it may be slowly changing. However, these findings are not yet firmly established and lack verification.
wolram
Dearly Missed
edit.
if space is expanding how can the electrical properties
stay constant?
It is believed that the fine stucture constant is not a constant. That is, it changes over time. This is not firmly established but there are some good indications (i.e. experimental data). Why would that interest me, you wonder?
Well the fine structure constant depends on 4 other constants:
- e: electrical charge
- c: speed of light
- h: Planck's cst
- e0: permittivity of space
[alpha]=e2/2e0hc
So if the fine stucture cst changes over time, one or more of these "constants" has to change. Since it is probably the permittivity of space that changes your question would be answered: they don't...
then i must be confused ,i thought that the 2Ps, governed
the speed of light ,if one of them is changeing how
can C be constant?
Like I said: this is not firmly established. There are also (Australian) experiments suggesting that the speed of light is not constant in time, but in fact slowly decreasing (or was it increasing). The problem is that there are no checks for these experiments yet.
thankyou HEUMPJE
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
