I'm going crazy (Electromagnetic Energy-Momentum Tensor)
The discussion focuses on the electromagnetic energy-momentum tensor and the manipulation of the antisymmetry property of the electromagnetic field tensor \( F^{\rho\lambda} \). The key transformation discussed is rewriting \( \nabla_\rho F_{\sigma\lambda} - \frac{1}{2} \nabla_\sigma F_{\rho\lambda} \) as \( \frac{1}{2}\left ( \nabla_\rho F_{\sigma\lambda} - \nabla_\lambda F_{\sigma\rho} - \nabla_\sigma F_{\rho\lambda} \right ) \). This transformation relies on the antisymmetry of \( F^{\rho\lambda} \), which leads to the conclusion that \( \nabla_\rho F_{\sigma\lambda} = -\nabla_\lambda F_{\sigma\rho} \). The solution provided clarifies the initial confusion regarding these tensor manipulations.
  • Understanding of tensor calculus, specifically the properties of the electromagnetic field tensor \( F^{\rho\lambda} \).
  • Familiarity with covariant derivatives and their notation, such as \( \nabla_\rho \).
  • Knowledge of the principles of electromagnetism as they relate to general relativity.
  • Ability to manipulate indices in tensor equations and apply antisymmetry properties.
  • Study the properties of the electromagnetic field tensor \( F^{\rho\lambda} \) in detail.
  • Learn about covariant derivatives and their applications in general relativity.
  • Explore the derivation and implications of the electromagnetic energy-momentum tensor.
  • Review advanced tensor calculus techniques for manipulating complex equations.
This discussion is beneficial for graduate students in physics, particularly those studying electromagnetism and general relativity, as well as researchers working on theoretical physics involving tensor analysis.
LineIntegral
The problem is conveniently located here:
http://www.dur.ac.uk/resources/cpt/graduate/lectures/mscps.pdf
Problem no. 31. There's even a solution, here:
http://www.dur.ac.uk/resources/cpt/graduate/lectures/grsolns.pdf
However, I don't understand the solution. How does the antisymmetry of [tex]F^{\rho\lambda}[/tex] allow us to rewrite [tex]\nabla_\rho F_{\sigma\lambda} - \frac{1}{2} \nabla_\sigma F_{\rho\lambda}[/tex] as [tex]\frac{1}{2}\left ( \nabla_\rho F_{\sigma\lambda} - \nabla_\lambda F_{\sigma\rho} - \nabla_\sigma F_{\rho\lambda} \right )[/tex] ? I just don't see it. This implies that [tex]\nabla_\rho F_{\sigma\lambda} = -\nabla_\lambda F_{\sigma\rho}[/tex], which doesn't seem right...
See above.
See above.
Any help will be much appreciated!
The point is that you have
[tex]F^{\rho\lambda} \nabla_\rho F_{\sigma\lambda} = \frac{1}{2} (F^{\rho\lambda}-F^{\lambda\rho}) \nabla_\rho F_{\sigma\lambda}.[/tex]
After a relabeling of dummy indices, you find the claimed result.
Thanks! Now it finally makes sense... :)
  • · Replies 30 ·
  • · Replies 16 ·
