I'm looking for some direction
  • Thread starter Thread starter crazy_shoes
    Direction
For a wireless data transfer solution that is directional and long-range, a low-power infrared (IR) laser is recommended as it is less likely to annoy or harm people. Additionally, exploring radio modems could provide effective options for precise data transmission. Directional WiFi antennas, such as Yagi antennas, can also facilitate PC-to-PC connections while ensuring data privacy through security features. The discussion highlights the importance of researching these technologies for optimal performance. Overall, various solutions exist that meet the criteria of being focused, fast, and harmless.
crazy_shoes
I'm looking for some sort of wireless data transfer and I need it to be very focused.
I need something similar to a TV remote, very directional, fairly long range. I'd like it to be as precise as possible and as fast as possible. I'd also like it to be as harmless as it can be, since lasers tend to hurt/annoy people.
Could someone tell me what it is that I am looking for? I know how to describe it but I'm not sure exactly what it's called or if it exists.
Thanks! :biggrin:
I would think that a low-power IR laser would be your best bet. It wouldn't annoy anyone because it can't be seen, and it's unlikely to cause any damage unless someone deliberatedly stared straight into the beam for an extended time.
Try a google search on radio modem.
Yeah, the radio modem angle may bear fruit. Also, remember that you can get pretty directional WiFi antennas, so you could just go PC-to-PC WiFi with a couple packaged Yagi antennas with decent directional gain. You use the WiFi password/security features, obviously, to keep your data private.
Wow, you learn something new every day! I'd never heard of radio modems before. This is some good stuff! Thank you all for your input.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
