I'm lost on this one, i think its a torque question.
  • Thread starter Thread starter linuxux
    Lost Torque
The discussion revolves around a physics problem involving a ladder leaning against a wall, where the goal is to determine how far a woman can climb before the ladder slips. Key points include the need to consider the angles, forces of friction, and the mass of the ladder and the woman. Participants emphasize the importance of identifying all forces acting on the ladder and suggest drawing a diagram for clarity. There is confusion regarding the calculation of the friction force, specifically whether it should be based on the total weight or adjusted for the angle. The conversation highlights the necessity of setting up a torque equation to solve the problem effectively.
linuxux
Hello, I'm working on an assignment for class and I am lost on this question.
problem
A 5.0m ladder is with a mass of 10.0kg is leaning against a smooth wall at an angle of 25 degrees. The coefficient of friction between the ladder and the ground is .30. How far can a 65kg woman climb up the ladder before the ladder starts to slip?
reasoning
obviously the angles come into play here, but I'm not sure in what way. Since the force of friction opposes motion, and the bottom of the ladder will move across the ground in a positive direction, the force of friction moves in a negative direction across the ground. I am not sure if the force of friction is just 0.30 x mg or if its 0.30 x mg cos 25 , also, I am not sure how to setup a torque equation, to solve this problem. Some hits would be appreciated, thanks!
Start by identifying all the forces acting on the ladder. Draw yourself a diagram!
thanks got it...
