I'm off by sqrt(2) and it's driving me crazy (expanded particle in 1D box)
  • Thread starter Thread starter quasar_4
    1d Box Particle
quasar_4
I believe this is a pretty standard question. A particle is initially in the ground state of a box of length L. Suddenly, the box expands symmetrically to twice its size, without disturbing the wavefunction. Show that the probability of finding the particle in the ground state of the new box is (8/(3Pi))^2.
We're using the box defined (initially) from -L/2.. L/2, and the potential is infinite everywhere outside the box. The ground state wavefunction should be sqrt(2/L)sin(Pi*x/L).
First I determined how we would renormalize the wavefunction in the new box, which extends from -L to L. So, I integrated \int_{-L}^{L} A^2 sin^2\left(\frac{n \pi x}{2L}\right) dx and got the new wavefunctions to be \sqrt{\frac{1}{L}} sin{\frac{n \pi x}{2L}}.
Now if I understand correctly, the probabilty of finding the particle in the new ground state is simply the square of the projection of this new state vector onto the old ground state vector. So I then integrated \int_{-L}^{L} \sqrt{\frac{2}{L}} sin\left(\frac{\pi x}{L}\right) \sqrt{\frac{1}{L}} sin\left(\frac{\pi x}{2L}\right) dx = \frac{8 \sqrt{2}}{3 \pi}.
If you square this, it's correct except for the square root of two (which makes my prob. off by a factor of 2!).
The extra \sqrt{2} is driving me crazy! What am I doing wrong?
If it helps, I can see that using the normalization factor sqrt(1/L) for both wavefunctions would produce the correct answer, but I don't understand why I'd tack the new normalization onto my old wavefunction. If someone can explain this I'd be much obliged...
Do you really want to integrate this from -L to L?...Isn't the particle in the state
\psi(x)=\begin{array}{lr} \sqrt{\frac{2}{L}} sin\left(\frac{\pi x}{L}\right) &, |x|\leq\frac{L}{2} \\ 0 &, |x|>\frac{L}{2}\end{array}
I suppose that makes more sense, since the initial state isn't defined past L/2.
The only problem is that that integral would then give me 4/3*pi, which is still off by a factor of 2!
Isn't the ground state \sqrt{\frac{2}{L}}\cos\left(\frac{\pi x}{L}\right)[/tex]?
Aha!
I always forget that the sine solution goes with the even integers (I tend to associate sine to odd things).
That totally solves my problem; thank you! :-D
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
