Im stuck: Energy in rotational motion
The problem involves calculating the change in gravitational potential energy of a 12.0m uniform rope with a mass of 3.00kg when it falls to the floor. Initially, the potential energy is calculated using the full length of the rope, resulting in 352.8 J. However, it is clarified that the center of mass of the rope is at 6.0m, not 12.0m, which is crucial for an accurate calculation. The correct approach requires using the height of the center of mass to determine the potential energy change. Thus, the final potential energy change should be recalculated based on this height.
Edwardo_Elric
A uniform rope 12.0m long and with a mass 3.00kg is hanging with one end attached to a gymnasium ceiling and the other end just touching the floor. The upper end of the rope is released, and the rope falls to the floor. What is the change in the gravitational potential energy if the rope ends up flat on the floor(not coiled up) ?
Fx = 0
Fy = 0
U = mgh1 - mgh2
Fy = 0 = Tsin(theta) - W
Tsin(theta) = W
T = ((3(9.8))/(sin(theta))
Fx = 0 = Tcos(theta)
No other force acts on the x-axis
change in gravitational potential energy = mgh2 - mgh1
that's all you need.
I thought it was inclined
U = mgh2 - 0
= (3.00kg)(9.8m/s^2)(12.0m)
= 352.8 J
thankss
U = mgh2 - 0
= 352.8 J
thankss
wait. use the center of mass... what's the height of the center of mass? you need to use 6.0m not 12.0m.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
