Why does the size of an image in a plane mirror not change when drawn on paper?
The size of an image in a plane mirror appears unchanged when drawn on paper, despite the object's distance. When an object moves away from the mirror, the image seems smaller due to the increased distance, but the actual size remains constant. The image appears to be the same distance behind the mirror as the object is in front. Observing a distant object in a mirror shows that the size appears consistent, while closer objects seem smaller. Thus, the perception of size is influenced by the apparent distance from the mirror.
Puneeth423
When an object is moved away from a plane mirror, its size decrease when seen in the mirror. But, when we draw image on paper for an object in different positions in a plane mirror, the size of the image doesn't seem to change. Why? Will the size change or not?
Science news on Phys.org
The size of the image doesn't change, but it looks smaller since it is farther away.
The image in a (plane) mirror will appear to be the same distance behind the mirror as the object is in front of the mirror. Stand near a mirror and look at a distant object and then at its image. They will appear pretty much the same size.
Stand by the same object and look at its image in the same mirror and the image will look much smaller than the object.
Size and (apparent) distance 'go together'.
