Calculating Speed and Force in Water Jet Impact | Fluid Mechanics Homework
  • Thread starter Thread starter pedro97
    Impact Jet Water
The discussion revolves around calculating the speed of water leaving a plate and the forces required to maintain equilibrium in a fluid mechanics scenario. The initial speed of the water jet is given as 2.02 m/s, and after striking the plate, it splits into two jets, leading to a calculated exit speed of 0.9198 m/s. The components of the force needed to keep the plate in equilibrium are determined to be F_x=28.48 and F_y=-389.7. Participants emphasize the application of the momentum conservation equation and express uncertainty regarding the correct approach for calculating the forces. The conversation highlights the importance of understanding macroscopic momentum balance in fluid dynamics.
pedro97
"A jet of water issues from a nozzle, of diameter h_1=0,102 m (and depth b=1 m), at a speed U_1=2,02 m/s. The jet strikes a flat plate of mass M=2,05 kg, as shown in figure, and it breaks into two jets of equal speed and diameter h_2=0,122 m and h_3=0,102 m. Determine the speed at which the water leaves the plate, U. Knowing that α=30° and that the volume in transition is V=5,05 L, find the components F_x and F_y of the total force that should be applied on the plate to maintain it in equilibrium". (Solutions are U=0.9198, F_x=28.48 and F_y= -389.7).
-Momentum conservation equation
-Fluid mechanics equations
To answer the first question, I took the jet as my control volume and I applied the momentum conservation equation on it:
(-ρU_1h_1b)+(ρUh_2b)+(ρUh_3b)=0
So: U=(U_1h_1)/(h_2+h_3)= 0.9198
My doubts concern the second question: I think I should use the rate of change of momentum, but I'm not sure how to continue this...
Tell us what you've learned about the macroscopic momentum balance equation, and discuss how it might be applied to this problem. Also, tell us why your first equation is not a momentum conservation equation.
