Impedance matching for audio amp
2 replies · 3K views · last reply
david90
Will an audio amp burn up if the speaker connected to it has a lower impedance than the amp's output impedance?
This question is too vague to answer. It depends on how the amp was designed, how much lower the load impedance is than the output impedance, and how high you turn up the volume.
You are probably confusing the output power rating of the amp with the output impedance of the amp.
The output impedance of a good quality modern audio amp using semiconductor circuits will be MUCH lower than the impedance of any speaker system you connect to it. It may be of the order of 0.01 ohms or less. But that is irrelevant to the poiwer rating of the amp.
The number you are interested in is the power rating, which should specify the nominal impedance of the speaker system (e.g. "100 watts into 4 ohms").
If you connect a speaker system with lower impedance than the power rating specifies, then you will be able to overload the amp, and that could produce audio distortion, thermal shutdown, blown fuses, or more serious damage.
