Implications of the statement Acceleration is not relative
  • Context: Graduate
  • Thread starter Thread starter GregAshmore
    Acceleration Relative
335 replies · 43K views
GregAshmore said:
If no plausible explanation for the workings of the gravitational field can be given, the field must be considered a pure fiction; ad-hoc hand-waving. In that case, the absoluteness of acceleration is not removed, at least with respect to SR.
Gravity produces coordinate acceleration but rockets produce proper acceleration. The field that Einstein conjures up produces the first kind - which is relative. But, as you have been told, proper acceleration is not coordinate dependent and cannot be made to disappear or appear by a change of coordinates. Proper acceleration is absolute in this sense.
Personally, I have no stake in the argument. I don't care if there is an absoluteness to acceleration. But the issue was important to Einstein, and having come this far, I'd like to be able to evaluate whether he succeeded in eliminating the problem.
Again, it's been said before, Einstein does not make it clear which kind he refers to so he has not succeeded, in my opinion.
GregAshmore said:
I don't assume anything with regard to which kind of observer can consider himself at rest.
Then we're missing a big piece of the puzzle, because we haven't established, have we, that the principle of relativity applies to *inertial* observers? If we haven't even done that, how can we do it for non-inertial observers?
GregAshmore said:
I don't think that is true, as a matter of logic. "At rest" must have an absolute meaning for the observer who claims it.
How can it be absolute if it's only true for the observer who claims it? Doesn't that make it relative? Isn't that the whole *point* of making the distinction between "relative" and "absolute"?
GregAshmore said:
Einstein's stated goal was to show that acceleration does not have any absolute quality.
Just like "motion" and "rest". That was his whole point. He wasn't trying to argue that motion or rest were absolute. If you think he was arguing that, you have seriously misunderstood his point.
GregAshmore said:
The charge is, "You are accelerating; therefore I am certain that you are in absolute motion." Einstein counters the charge with, "No. I am permanently at rest."
No, you're misunderstanding what he said. A better statement of his counter is: "No. There is no such thing as absolute motion. Acceleration, like motion and rest, is relative." Then he investigates what it takes to consistently maintain such a position, and finds out that to do so, we must also accept that a "gravitational field" (in the sense of "acceleration due to gravity"--mathematically, as DaleSpam pointed out, this corresponds to Christoffel symbols, first derivatives of the metric) is relative; it can be present in some frames and absent in others.
GregAshmore said:
In the context, I thought it was clear that I meant every resting observer.
Huh? The position you have been taking is that *every* observer can consider himself to be at rest, so "resting observer" just means any observer whatsoever. *I* can draw distinctions like the one I drew in what you quoted--nobody in real life considers himself to be "at rest" and the grocery store to be moving--because I'm arguing that relative motion is what's important anyway. But how can *you* draw such distinctions without undermining your whole position?
GregAshmore said:
The effect of the field is not felt until the Earth accelerates. But the Earth only accelerates due to the effect of the field.
No, the effect of the field is always there. When the rocket engine is off, the rocket and the person inside are free-falling in the field along with the Earth. When the rocket engine fires, it holds the rocket and the person inside at rest in the field so they can't free-fall with the Earth. So the Earth appears to accelerate "downward". But the field is always there; firing the rocket engine just prevents the rocket from free-falling in it.
PAllen said:
What do you think of the following:
My reply will have to wait until tomorrow night.
GregAshmore said:
I'd like a yes or no answer.
:rolleyes: OK
GregAshmore said:
Does this mean that we can put an engine-less pod in space (without gravity due to mass, per the scenario) and then select the appropriate mapping, at will and as needed, to accelerate the Earth and stars until the star of our choice meets up with the pod?
No.
GregAshmore said:
After the resting rocket twin fires his engine and sees the Earth accelerate away, he eventually sees his target star approach. He can measure the distance to the star at intervals and verify that it is indeed getting closer. You have said repeatedly that the motion of the Earth is caused by the choice of coordinates, independent of the firing of the rocket. I give you the very same scenario, except without an engine in the rocket. Can you make the very same events happen?
No.
GregAshmore said:
Can you cause the Earth and stars to move by selecting a certain coordinate system?
Yes.
All of physics is that kind of "fiction". But it is "fiction" that describes nature quantitatively and allows predictions. Newton didn't explain the workings of his gravitational field either. He just quantified it, and this "fiction" still works great for most purposes.
stevendaryl said:
The laws of physics are not violated by noninertial coordinates, it's just that they have a different form when they are expressed in noninertial coordinates.
For example, Newton's laws of motion, when described using inertial Cartesian coordinates x and y, look like this:
[itex]\dfrac{d^2 x}{dt^2} = \dfrac{1}{m} F^x[/itex]
[itex]\dfrac{d^2 y}{dt^2} = \dfrac{1}{m} F^y[/itex]
If we change to a new coordinate system
[itex]r = \sqrt{x^2 + y^2}[/itex]
[itex]\theta = arctan(\dfrac{y}{x})[/itex]
then the same equations of motion look like this:
[itex]\dfrac{d^2 r}{dt^2} - r (\dfrac{d\theta}{dt})^2 = \dfrac{1}{m} F^{r}[/itex]
[itex]\dfrac{d^2 \theta}{dt^2} + \dfrac{2}{r} \dfrac{dr}{dt} \dfrac{d \theta}{dt} = \dfrac{1}{m} F^{\theta}[/itex]
They're the same laws of motion, except written in different coordinates. The form of the laws change in different coordinates, but the physical content does not.
True, the physical content does not change in this example.
stevendaryl said:
The laws of physics look different in noninertial or curvilinear coordinates, but they have the same physical content.
This is not true in the case of the resting rocket. In that coordinate system, no force acts on the Earth, yet it accelerates. And, an unbalanced force acts on the rocket, yet it does not accelerate. Both of these phenomena violate Newton's law as quoted above. Additional physical content is proposed as an explanation: a gravitational field. Additional term(s) are needed in the equation to express the behavior of the additional physical content. I believe (but can't say for sure) that the equation presented by DaleSpam in #278 corresponds to the law of Newton quoted above, with the addition of Christoffel symbols to account for the gravitational field.
- The rocket cannot consider themselves inertial. This means that the simplest form of laws of physics cannot be used. A more complex way of expressing laws, that is also true (by natural vanishing of extra terms) for inertial motion, can be used. Thus, if you choose the more complex expression, laws are the same for all motion; however, this in no way changes that inertial and non-inertial motions are in-equivalent.
- The rocket is clearly at rest relative relative to itself. There is no escaping this, so it is clearly a legitimate thing to recognize.
Yes to both points.
PAllen said:
What can you possibly mean by this? How can the universe become less real because you are in a rocket firing thrust? I assume this isn't really what you mean, but I am at a loss for what you possibly could mean.
The universe as depicted by the observer in the resting rocket has a homogenous gravitational field of vaguely specified origin. That gravitational field is necessary to maintain the claim that the rocket is really at rest. The reality of this gravitational field is questionable; hence the reality of the universe that contains it is questionable.
PAllen said:
I can sympathize with this. Normally, you do not picture that distant mountains move rapidly when you turn your head. However, what would lead to a real problem is trying to apply the simplest form of laws to the 'turning head' frame. The simplest form of laws (only valid in inertial frames) says no matter can travel faster than the speed c. In the turning head frame, there are no limits on coordinate speed; but this law remains in a different way: no matter catches a pulse of light.
Ok. Still, one must remember that certain measurements cannot be trusted as valid at face value. It wouldn't do for someone at rest in such a coordinate system to insist, based on his measurements, that the universe does allow objects to travel at speeds greater than c. That universe would not be real.
PAllen said:
Proper acceleration calculation has been explained a few times in this thread. I will not repeat. However, I stress that proper acceleration can easily be non-zero for an observer at rest in non-inertial coordinates. As I tried to express it above, the rocket is indisputably at rest relative to itself. However, it is also indisputably non-inertial, which allows proper acceleration to be nonzero for an observer at coordinate rest.
Yes. But if by pointing this out you mean to say that non-zero proper acceleration implies "actual" or "real" or "absolute" acceleration, the resting rocket observer is under no obligation to concede the point. He acknowledges that he was non-inertial; he does not acknowledge that he accelerated. Is there any physical evidence that will compel him to acknowledge that he accelerated?
Fiction to some degree perhaps. But there are surely degrees of fiction. Newton could point to specific massive bodies and specific distances between them to explain the cause of specific gravitational effects. That kind of detail is missing from the explanation for the behavior of the resting rocket.
Is the argument for absolute acceleration compelling? The physical phenomenon that is indisputably present in all coordinate systems is the unbalanced force. The physical reality of the worldline path is not an indisputable fact in any coordinate system, as I understand the concept. The rocket observer acknowledges that he is non-inertial; he sees the non-zero reading on his accelerometer. To him, this indicates an unbalanced force, and nothing more. He can say, "I would have accelerated if I hadn't been held back by the gravitational field." I don't see how an appeal to the worldline can overcome this objection. In short, assuming that his gravitational field is plausible, all he is compelled to recognize are the measurements that are made by the instruments in his coordinate system. Those measurements do not indicate that he moved.
You must say whether you mean proper or coordinate acceleration. I've nothing to add to what I said about the transformation of proper acceleration.
I don't know what an 'unbalanced' force is. Presumably one that meets no resistance. But it is the inertial resistance of the rocket to its engine thrust that balances the rocket thrust. And that can't be transformed away.
I have to disagree. The worldlines of the involved parties are *actually* what happens, and the physics they contain is coordinate independent. For instance, worldlines crossing, or approaching or separating are facts that cannot be changed by transformations. A worldline is an itinerary - it tells us where and when the object is.
Sorry, I don't get the point of this bit.
We can find coordinates in which the rocket observer is at rest, but ( to him ) the things around him will appear to be moving.
Reading some of your ither replies - I think you are still a bit confused. You ask
Obviously there is. He will feel his weight and the accelerometer shows a reading. Inescapable evidence of acceleration. Motion is relative, so acceleration is not evidence of motion. You seem to think that because something feels acceleration, it must also change it's state of motion. But an object at rest in the Earth's field still feels acceleration, so acceleration can also make something stop moving ( in a certain frame ).
DaleSpam said:
:rolleyes: OK
No.
No.
Yes.
Back to the original scenario.
1. Prior to the firing of the rocket, if you select the specific coordinate system, do you make both the Earth and the rocket move, and in such a way as to maintain unchanged the distance between them?
If the answer to 1 is yes, please go on.
2. If you repeatedly select and deselect the specific coordinate system prior to the firing of the rocket, will the result each time be the same as in 1, making both the Earth and the rocket move, and in such a way as to maintain unchanged the distance between them?
3. If you select the specific coordinate system during the firing of the rocket:
3a: Will you make the Earth move?
3b: Will you make the rocket move?
My question is whether the resting rocket observer is compelled by any evidence to accept that he accelerated.
It's tough to satisfy everyone on the forum. I once said "force" unqualified, meaning a force that would cause acceleration as judged from an inertial frame, and was corrected for being ambiguous.
What hard evidence do you have that there is such a thing as a wordline? I've spent thousands of hours working with accelerating masses; I've never seen any evidence of such a thing.
We can find coordinates in which the rocket observer is at rest, but the things around him will appear to be moving in complicated way.
When you tell the resting rocket observer that he is absolutely accelerating, it makes no difference to him whether you say "proper" or "coordinate" acceleration. Acceleration implies movement. The fact that the movement (distance traversed) is shown on a worldline instead of in his coordinates does not change the fact that you are claiming that he moved. He denies movement.
Really? I deny it. It is inescapable evidence that I am being pushed against my seat. It is not evidence that my seat is moving.
I thought I answered that.
Have a look at this
http://en.wikipedia.org/wiki/World_line
Yes it does. With no proper acceleration there is no weight or accelerometer reading. An object can accelerate towards the Earth and be weightless.
Movement is relative. Acceleration does not always imply movement.
I thought you didn't believe in worldlines :wink:
I did not say it was such eveidnce. I've tried really hard to make the point that acceleration is not evidence of movement. You keep saying it, though.
Everybody is always moving according to some observer somewhere. Movement is relative.
Anyhow, I have to quit now.
The questions, as asked, are unanswerable. I have modified them as little as possible to make them answerable.
GregAshmore said:
1. Prior to the firing of the rocket, if you select the specific coordinate system, [STRIKE]do[/STRIKE] can you make both the Earth and the rocket move, and in such a way as to maintain unchanged the distance between them?
Yes.
GregAshmore said:
2. If you repeatedly select and deselect the specific coordinate system prior to the firing of the rocket, [STRIKE]will[/STRIKE] can the result each time be the same as in 1, making both the Earth and the rocket move, and in such a way as to maintain unchanged the distance between them?
Yes
3a: [STRIKE]Will[/STRIKE] can you make the Earth move?
Yes.
GregAshmore said:
3b: [STRIKE]Will[/STRIKE] Can you make the rocket move?
Yes.
You have enormous flexibility in choosing coordinate systems. You can choose charts such that each of those statements is true. You can also choose charts such that each is false.
Have a look at this
The bolded text highlights our disagreement. You say that acceleration does not imply movement. I say that the definition of acceleration implies movement; by definition, there is no acceleration without movement.
As I understand your position, the distinction between coordinate acceleration and proper acceleration allows you to say that there can be acceleration without movement. That position cannot withstand logical scrutiny.
I begin with a caveat:
The definition of proper acceleration has been given as "calculated along the path of the worldline." This definition is ambiguous because it does not define how the worldline is constructed.
In this thread several methods for constructing the worldline of the rocket have been proposed. One of these had the rocket at the same position throughout, so the acceleration along that path would be zero. Obviously, that cannot be the method that is to be used.
Whatever the method that is to be is to be used, the path along the worldline must have non-zero length; the worldline must show the rocket as having traveled some distance. (I suppose that the worldline of the rocket is to be drawn with reference to an inertial frame, but that is not necessary for the success of my argument.)
Here is my logic:
1. An absolute quantity cannot be dependent on a non-absolute quantity.
2. Proper acceleration is absolute.
3. Proper acceleration is derived from, and therefore dependent on, proper velocity.
4. It follows that proper velocity is absolute.
5. Proper velocity is derived from, and therefore dependent on, the distance traveled along the worldline.
6. It follows that the distance traveled along the worldline is absolute.
7. The distance traveled along the worldine is, by definition, the distance through spacetime traveled by the rocket.
8. A "distance traveled" is by definition "movement".
9. It follows that the rocket has experienced absolute movement through spacetime.
[Aside: I have seen the terms "proper acceleration" and "proper velocity" in this thread. I have not seen the term "proper distance." It seems to me that "proper distance" is the appropriate term for the distance through spacetime traveled by the rocket.]
When you tell the resting rocket observer that he had proper acceleration, you are also telling him that he moved some absolute distance through spacetime. That is precisely the charge he intended to deny when he made the claim to be permanently at rest.
From the wikipedia article you referenced:
The concept of "world line" is distinguished from the concept of "orbit" or "trajectory" (such as an orbit in space or a trajectory of a truck on a road map) by the time dimension, and typically encompasses a large area of spacetime wherein perceptually straight paths are recalculated to show their (relatively) more absolute position states — to reveal the nature of special relativity or gravitational interactions.
Personally, I am much more inclined to accept the argument for relative motion through absolute space than to accept the argument for a gravitational field that holds the rocket still while its engine is firing. Even so, the notion of absolute space is an abstraction. The resting observer in the rocket is not compelled by any direct evidence to acknowledge the reality of that abstraction.
It would help if you would avoid the unqualified term "acceleration". I believe that you mean that "proper acceleration does not always imply movement".
The world line can be considered in any coordinates, including one where the rocket always has coordinate position zero, and is a vertical line in said coordinates. In such coordinates, the coordinate acceleration is zero and the proper acceleration is non-zero. The proper acceleration is defined as a covariant (or absolute) derivative of 4-velocity along the world line. Note that 4-velocity has a nonzero time component in such coordinates. This absolute derivative (of 4 velocity by proper time - which is just measured clock time for the rocket) has, as part of its expression, connection coefficients. These can be related to measurements of g forces. Thus the rocket, setting up coordinates themselves, at rest in those coordintes, directly computing proper acceleration according to its defining formula expressed in those coordinates, comes up with a nonzero value.
Can you provide a link to an explanation of the steps in this calculation?
Yes, I fell into the same error I was advising against.
:redface:
Yes.
Yes
Yes.
Yes.
You have said that you can cause motion by choosing a specific coordinate system. I am asking questions about what happens when that specific coordinate system is chosen. You can't avoid answering the questions by attempting to use some other coordinate system(s).
I'll ask two simple questions for now.
1. Prior to the firing of the rocket engine, you select the specific coordinate system. Do you make the rocket move?
2. While the engine is firing, you select the specific coordinate system. Do you make the rocket move?
Only two that are of relevance:
- influences quantitative predictions (physics)
- doesn't influence quantitative predictions (not physics)
See:
http://en.wikipedia.org/wiki/Proper_acceleration#In_curved_spacetime
noting that the calculations they give for curved spacetime also apply exactly to non-inertial coordinates in flat spacetime (special relativity). Also, they really apply to inertial coordinates as well, except that the connection coefficient goes to zero.
I can't find a good online link right now for the relation of connection coefficients to physical measurement, but it is well known that in the local 'rest frame' of an accelerating rocket (with no spin), all the connection coefficients are zero except the (x,tt), (y,tt), and (z,tt) components, and that these correspond to the measured g force in the x,y and z directions. For g force felt doesn't change direction, you can define x as the direction in which you feel g force; then only the (x,tt) connection component is nonzero, and it is (within units) equal to the g force you measure.
Then, the formula for proper acceleration I linked, in a rocket rest frame, the (ordinary) derivative of the 4-velocity is zero; and the only term of the connection expression that doesn't vanish is the (x,tt) component = g force, times the time component of 4-velocity (which is the only component non-zero for such an accelerated frame) squared. You get, finally, that proper acceleration computed in rocket rest frame is proportional to g-force measured in rocket rest frame.
[One reference that covers all of this in detail, but at a much more advanced level than I assume is appropriate for you, is section 13.6 of Gravitation, by Misner, Thorne, and Wheeler.]
Here is the wikipedia page on worldlines: http://en.wikipedia.org/wiki/World_line
It doesn't give a good definition, but should give you the idea. Perhaps someone else with a good textbook can give a formal definition.
The proper acceleration along a worldline can be non-zero even if the object is at the same position throughout (coordinate acceleration is zero). The classical example is that of an object at rest in Schwarzschild coordinates (e.g. sitting in a chair on the surface of the earth).
The path does need to have non-zero length, but that length can be purely in the time dimension. For an object "at rest" their worldline does not travel any spatial distance, but instead mantains a constant spatial position and parallels the time axis.
GregAshmore said:
Here is my logic:
I assume that by "absolute" you mean "frame invariant". However, this statement is wrong.
The prototypical example of an invariant quantity is the spacetime interval [itex]ds^2=-c^2dt^2+dx^2+dy^2+dz^2[/itex]. As you can see, the spacetime interval is dependent on frame variant quantities, both in terms of being logically dependent (definition) and mathematically dependent (derivatives). But those dependencies are such that under a change of frame the spacetime interval remains unchanged.
The property of frame variance or frame invariance cannot be deduced simply by the method of looking to see if it is dependent on a frame variant quantity.
Yes. (again assuming "absolute" means "frame invariant")
OK. Although that isn't the only way to define it.
No that doesn't follow. See 1 above. However, proper velocity is the spacelike part of the four-velocity which is absolute.
I am not sure what you mean here.
The spacetime interval along the worldline is indeed absolute (frame invariant). I don't think that it follows from the above, but it is correct.
Yes, but it is better to use the term spacetime interval rather than distance. In the case of a massive object like a rocket the interval is timelike so it is a "distance" which is measured by clocks.
I have no problem with this. It seems to lend itself more to a LET-type interpretation of relativity than a block-universe interpretation, but I think it is OK.
No problem with this either, but the movement that you are describing is like the movement of a cursor pointing to different points along a fixed line.
No, when the resting rocket observer sees his clock tick he is moving some absolute distance through spacetime. The proper acceleration is not relevant. You cannot stop moving through spacetime simply by being at rest in space.
An absolute quantity cannot be defined in terms of a non-absolute quantity, but it is often convenient to use non-absolute quantities for calculating about absolute quantities, and then the mechanics of the calculation may depend on a non-absolute quantity. For example:
The distance between a ship on the surface of the ocean and the location of an iceberg is an absolute quantity; either that distance is zero and the ship is sinking or it's non-zero and the ship isn't sinking. However, when the coast guard broadcasts an iceberg warning, it uses non-absolute coordinates (latitude and longitude, zero longitude is chosen based on an accident of British maritime history) to identify the location of the iceberg; and it's up to the ship's captain to calculate the absolute distance between his ship and the iceberg.
The ship's captain uses a formula involving the (non-absolute) latitude and longitude to calculate the (absolute) distance so, it's easy to make the mistake of thinking that the distance is defined in terms of latitude and longitude. In fact the absolute distance is defined by the two absolute points (location of ship and location of iceberg) and the latitude and longitude values were determined by those points.
True enough, but of very little practical significance as there is no serious disagreement as to what a worldline is nor how to construct them.
What is confusing is that there are different ways of drawing them, according to the coordinate axes you use. For example: The worldline of a particle hovering just outside a black hole will look like a vertical straight line on a piece of paper if you use the Schwarzschild t coordinate as the vertical axis and the r coordinate as the horizontal axis. Use K-S coordinates for the axes and the worldline will look like a hyperbola on your sheet of paper. But we're talking about the exact same set of points in spacetime either way.
The physical laws are never changed by changing coordinates. Coordinates are just labels we give to points in space and time. Whether we label points by (x,y,z), or by latitude and longitude and altiude, or by (r,θ,[itex]\phi[/itex]), can't make any difference to the physics.
But coordinate acceleration isn't physical. Or at least, it's only partly physical. An object's coordinate velocity can change because the object is being acted on by a force, but it can also change because your coordinate system is curvilinear or noninertial. The physically meaningful quantity is not coordinate acceleration, but acceleration relative to the inertial paths.
Mathematically, proper acceleration, which is the physically meaningful quantity, is expressed as:
[itex]A^\mu = \dfrac{d U^\mu}{d \tau} + \Gamma^\mu_{\nu \lambda} U^\nu U^\lambda[/itex] where [itex]U^\mu[/itex] is proper velocity, and [itex]\Gamma^\mu_{\nu \lambda}[/itex] is the so-called "connection coefficients" that are different for different coordinate systems. The two pieces of the proper acceleration
[itex]\dfrac{d U^\mu}{d \tau}[/itex]
and
[itex]\Gamma^\mu_{\nu \lambda} U^\nu U^\lambda[/itex]
are not physically meaningful by themselves, but the combination is physically meaningful.
Not necessarily. Drawing the worldline just requires choosing some convention (aka frame) for assigning coordinates to points on the worldline; then draw coordinate axes on a piece of paper; and start plotting points using these axes. There's no requirement for an inertial frame here.
(It is true that it's generally easier to draw straight lines, and in flat spacetime the worldline of an object that is experiencing no proper acceleration will be a straight line using an inertial frame and Minkowski coordinates, so we tend to use these a lot. But that's just a convenience).
I should point out that if you buy that the physics is not changed when you go from Cartesian coordinates to Polar coordinates, then it's exactly the same type of change in going from inertial coordinates to noninertial coordinates.
In rectangular coordinates, the path of an object traveling inertially is given by:
[itex]\dfrac{d^2 x}{dt^2} = 0[/itex]
[itex]\dfrac{d^2 y}{dt^2} = 0[/itex]
In polar coordinates, the same path is given by:
[itex]\dfrac{d^2 r}{dt^2} = r (\dfrac{d \theta}{dt})^2[/itex]
[itex]\dfrac{d^2 \theta}{dt^2} = -\dfrac{2}{r} \dfrac{dr}{dt} \dfrac{d \theta}{dt}[/itex]
Since [itex]\dfrac{d^2 r}{dt^2}[/itex] can be nonzero even with no physical forces acting, an object will "accelerate" without any physical cause for that acceleration. An object's radial velocity is not constant, in general, even with no forces acting. The physically meaningful acceleration is not [itex]\dfrac{d^2 r}{dt^2}[/itex], but the combination
[itex]\dfrac{d^2 r}{dt^2} - r (\dfrac{d \theta}{dt})^2[/itex]
To get into the "spirit" of relativity, you should think in terms of everything moves. For any object whatsoever, if it waits a second, it's at a different spacetime location than it was a second ago. So everything has a nonzero velocity through spacetime. But you can choose coordinates so that the spatial component of velocity is zero for some object.
There's always this visualization from Epstein:
"The reason you can't go faster than the speed of light is that you can't go slower. There is only one speed. Everything, including you, is always moving at the speed of light."
http://www.relativity.li/en/epstein2/read/c0_en/c1_en/
