Implicit differentiation - Help
pat666
find y' given x3+y2+x+y=2
dy/dx=3x2+2y(y')+1+y'
I know that's wrong because my 89 gives it as y'=(-3x2+1)/(2y+1), I don't know how to get there though and what happened to the =2.
Thanks
Thanks
You turned the 2 in the original equation to dy/dx, instead of d(2)/dx, but the rest is correct. You should have 3x2+2y(y')+1+y'=0, then put the non-y terms on the right and factor out y' from 2y(y')+y' and you'll have the book's answer.
It also seems like the correct answer should have (-3x2-1) rather than (-3x2+1).
I've gotten closer to the solution but now I'm stuck at
3x^2+1=1-1-y'-2y(y')
3x^2+1=-y'-2y(y')?
Thanks
Now factor y' out of -y'-2y(y'). You'll have (-1-2y)y'. Then divide both sides by -1-2y.
Another thing..
in your last reply, you have =1-1-y'-2y(y'). Where did the 1-1 come from? If this is d(2)/dx, then it's sort of incorrect. The derivative of a constant is always 0; 1-1 is of course equal to zero, but writing 1-1 is sort of confusing for the person who's error checking.
yeah, I see what you mean - ill avoid doing that... Thanks for your help.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
