Implicit differentiation - messed up somewhere
meredith
find d^2y/dx^2 at (1,1) for:
x^2y + x^2 -y^2 = 1
none
i worked it all out but the answer I am getting is not an option. could someone show me where i made a mistake? I am not asking you to do the problem for me, just fix my error. this is what i did:
first i found dy/dx:
x^2(dy/dx) + y(2x) +2x -2y(dy/dx)=0
(x^2 - 2y)(dy/dx) = -2xy - 2x
dy/dx = (-2xy-2x)/(x^2-2y)
when i put (1,1) in, i got 4
then to find the second derivative i used the quotient rule:
d^2y/dy^2 = [(x^2-2y) (-2x)(dy/dx) +y(-2) -2] - ((-2xy-2x)(2x-2)(dy/dx)]/(x^2-2y)^2
then i just put the values in. for the x's and y's i put in 1, and for dy/dx i put in 4. i ended up with:
[(-1 x -2 x 4 + -2 -2) - (-2 -2) x (2-2(4) ] / 1 = 28 ? but this answer is incorrect. what did i do wrong?
Thanks so much!
It's not necessary to solve for dy/dx- just use implicit differentiation again.
You are correct that x^2(dy/dx) + y(2x) +2x -2y(dy/dx)= 0.
Now, (x^2(dy/dx)'= x^2 d^2y/dx^2+ 2x dy/dx, (2xy)'= 2xy'+ 2y, and (2y dy/dx)'= 2y d^2y/dx^2+ 2 (dy/dx)^2. Put those together.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
