Implicit Function Theorem problem
KevinMWHM
Part 1. If I want to solve the system;
u-v = (h-a)e^-s
w-u = (k-b)e^-t
ae^s = be^t
for a, b, u, in terms of the remaining variables using the implicit function theorem...
If I want to know when I can solve, can I just say f(a, b, u) can not = 0? And if I set a, b, u, = 0
Than I get k and h can not = 0.
Part 2. Calculate du/ds, da/ds, db/ds, by exhibiting a linear set of equations.
So for da/ds for example, solve equation 1 for a giving;
d(-e^s(u-v)+h)/ds?
I don’t need to solve the system.
u-v = (h-a)e^-s
w-u = (k-b)e^-t
ae^s = be^t
d(-e^s(u-v)+h)/ds?
For Part 1, you don't NEED to solve the system, but the easiest solution is to just go ahead and solve it anyway! Using the notation ##S = e^{-s}## and ##T = e^{-t}##, write your equations as
u-v = (h-a)S\\<br /> (w-u)=(k-b) T \\<br /> a/S = b/T<br />
This is a simple linear system, from which you can easily find ##a,b,u## in terms of ##v,w,h,k,S,T##.
For Part 2, you can also derive a simple linear system for ##\partial a/ \partial s, \: \partial b / \partial s, \: \partial u / \partial s## and get a solution in terms of ##a,b,u,v,w,h,k,S,T##, using the definitions of ##S,T## in terms of ##s,t##.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
