Improper integrals with infinite discontinuities
12 replies · 4K views
nweis84
[tex]\int[/tex][tex]\frac{13}{(x-8)^2}[/tex]dx
it is integrated from 7 to 9 and i am aware that there is an infinite discontinuity at x=8 so we have to take the limit from both sides individually.
The only thing I can think that I might be doing wrong is just integrating it wrong but it seems like such an easy integration. The integration that I come up with:
-[tex]\frac{13}{x-8}[/tex]
as a goes to 8 [[tex]\frac{-13}{a-8}[/tex]+[tex]\frac{13}{7-8}[/tex]]+[[tex]\frac{-13}{9-8}[/tex]+[tex]\frac{13}{a-8}[/tex]]
and this comes out to be -26 which has to be wrong because the graph is above the positive x-axis and also it is not one of my answer choices.
I thought you said you were going to take the limit of both sides individually? This looks more like you threw both sides together first, and then took a limit.
I'm not really sure how to write it in there with this program but I did take the limits individually when I did the work on my paper. The first bracket is the limit from 7 to a as a approaches 8 from the left and the second bracket is the limit from a to 9 as a approaches 8 from the right. Did i do that right?
then don't you just add them in the end?
What were the limits on the two sides then? What two numbers did you add together to get -26?
both of them came out to -13
Interesting. Could you show how you calculated that?
lim as a --> 8- [ [tex]\frac{-13}{x-8}[/tex] ]
from 7 to a =
[[tex]\frac{-13}{(a-8)}[/tex]+[tex]\frac{13}{(7-8)}[/tex]]
[ 0 + [tex]\frac{13}{-1}[/tex]]
= -13
its the same basically for the other side
The 13/-1 makes sense. How did you get that 0?
well doesn't the 8- with the negative sign to the right of the number mean +8 but that it is approaching from the left side?
or are you saying that it means I should have plugged in a negative 8 for a?
or does that mean that that factor goes to infinity?
Bingo. ([itex]+\infty[/itex], I believe? You should check)
thanks for your help It's just been a while since calc I and i kinda forgot how to do limits
and yes one of the answer choices is that the integral diverges
