What Is the Correct Expression for the Force Fo in an Inclined Plane Problem?
The discussion focuses on determining the correct expression for the force Fo acting on a block accelerating up a frictionless inclined plane. The problem involves analyzing forces, including gravitational force and the applied force at an angle. Through various calculations and trigonometric identities, participants arrive at the conclusion that the correct expression for Fo is mg(1 + sin α)/cos(α + β). The solution process emphasizes the relationship between the angles and the forces acting on the block. Ultimately, the consensus confirms that choice 2 is the correct answer.
wmrunner24
A block of mass m accelerates with acceleration g up a frictionless plane that is inclined at
an angle α above the horizontal. The force Fo that pushes the block is at an angle β above
the horizontal. Find the force Fo.
1. mg(1 + sin β)/cos(α + β)
2. mg(1 + sin α)/cos(α + β)
3. mg(1 + sin β)/cos(α − β)
4. mg(1 + sin α)/cos(α − β)
5. mg(1 − sin β)/cos(β − α)
6. mg(1 + sin α)/cos(β − α)
7. mg(sin β)/cos(α + β)
8. mg(1 + sin β)/cos(β − α)
9. mg(1 − sin β)/cos(α + β)
10. mg/cos(α + β)
F=ma
a=g
\SigmaF=ma=mg=Fu-Fg
where Fu is the force up the incline and Fg is the force of gravity (down)
Fg=mgsinα
Fu is a little more complicated to figure out. Here's my idea:
A is the adjacent side between the two triangles and Fu is the force parallel to the incline. A is also parallel to the horizontal. Because of this double parallel setup, it can be seen as two sets of parallel lines and transversals, so the new angle can be identifed as α using geometry. Thus:
cosβ=A/Fo
cosα=Fu/A
F_{u}=Fo*cosα*cosβ
So then:
mg=Fo*cosα*cosβ-mgsinα
mg(1+sinα)/(cosα*cosβ)=Fo
There is a trig identity that allows me to rewrite this as:
2mg(1+sinα)/(cos[α-β]+cos[α+β])=Fo
This is where I am stuck. I'm at an answer similar to those given but not quite there. Any help is greatly appreciated.
wmrunner24 said:
So then:
your upward force \vec{F}_u is wrong. remember that a vector is same anywhere in the space as long as its direction and the length is the same. so bring that vector
\vec{F}_o
at the center of the block.. then what would be the angle between the vector
\vec{F}_o
and the inclined plane ?
So...
cos(α+β)=Fu/Fo
Fo*cos(α+β)=Fu
So then:
mg=Fo*cos(α+β)-mgsin(α)
mg(1+sin(α))/cos(α+β)=Fo
So choice 2. Right?
yes........
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
