Increase Outlet Pressure to 1.5 bar in Retrofitted Process Line
  • Thread starter Thread starter Faizal
    Pressure
To achieve an outlet pressure of 1.5 bar in the retrofitted process line, the pump's specifications must be evaluated to ensure it can handle that pressure. Suggestions include upgrading the pump, cleaning the system to improve efficiency, or raising the water tank elevation by about 10 meters to increase pressure naturally. Additionally, reducing friction by enlarging the exit pipes may help. The current flow speed and pump dynamics indicate that the two sides of the system are not effectively communicating, which complicates the pressure increase. Ultimately, the pump's capability is likely the primary factor affecting the desired outlet pressure.
Faizal
Hi all !
I currently in the process of retrofitting an old process line in which I require the outlet pressure to be 1.5 bar.
The design just includes an open tank connected to a pump as shown in attachment. The water level of the tank is leveled with the pump outlet. The pump is currently operating to produce an outlet flow of 33 LMH in a 1.5 in pipe.
By using Bernoulli's Equation, shown in attachment as well, I can't seem to increase the pressure by either manipulating outlet flow or reducing pipe size. I sincerely hope you guys can help by pointing out my mistake and a solution to increase the outlet pressure ?
Thank you very much for your kind assistance ! .. :confused:
Welcome to PF Faizal.
Is the pump capable of 1.5 bar? (see the specs)
What do you expect to see if you would get 1.5 bar? Could it be that you get 1.5 bar and without a stop the pressure just does nothing?
The speed of the flow is slow and there is a pump there so the two sides are not truly communicating. I see no need for the Bernoulli equation.
Options for increasing the exit pressure:
Overwork the pump/change the pump with something better. An overall clean-up will sometimes "up" the pressure.
Move the water tank to a higher elevation, approximately 10m => 1bar.
Make the exit pipes bigger for less friction.
IMO the main culprit is the pump if you do not get 1.5 bar.
Have fun!
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
