Increasing resistance and the effect on voltage
The discussion revolves around the effects of resistance on the electric field in a parallel plate capacitor system, particularly in the context of direct current (DC) circuits. Participants are exploring how different configurations of resistors and the addition of a battery influence the voltage and electric field between the capacitor plates.
  • Participants are analyzing the impact of adding resistors in series versus parallel on the voltage across a capacitor. There is confusion regarding whether increasing resistance affects the voltage applied to the capacitor, particularly in relation to Ohm's law (V=iR). Some participants are questioning the implications of DC current on the behavior of the capacitor over time.
The discussion is active, with participants providing insights into the behavior of capacitors in DC circuits. Some have suggested that adding resistors does not change the voltage across the capacitor, while others are considering the implications of time on charge accumulation. There is no explicit consensus on the correct answer, but various interpretations are being explored.
Participants are working under the assumption that the circuit is open at the capacitor and that the voltage across the battery remains constant. There is an ongoing examination of how these conditions affect the current flow and charge on the capacitor over time.
dr2453
Which of the following will most likely increase the electric field between the plates of a parallel plate capacitor?
(a) Adding a resistor that is connected to the capacitor in series
(b) Adding a resistor that is connected to the capacitor in parallel
(c) Increasing the distance between the plates
(d) Adding an extra battery to the system
E=V/d
V=iR
(c) was automatically out, as pe r E=V/d. I am stuck between between a, b, and c. I know that adding a battery would increase V, thus increasing E. However, I'm confused about whether increasing resistance decreases or increases voltage. According to V=iR, it seems like it should (there's nothing in the problem indicating whether i is constant). Does increasing resistance decrease or increase the voltage applied to the capacitor?
sorry, (b) was supposed to be Adding a resistor that is connected to the capacitor in parallel.
(d) mentions a battery, so we are talking about dc current. In this case, the circuit is open at the capacitor. So, adding a resistor in series doesn't change anything, this eliminates (a). Neither does adding a resistor in parallel, because the voltage stays the same. Since you ruled out (c) by yourself, the correct answer would be (d).
Thanks! That's what I thought the answer would be. But why does adding a resistor not change anything?
Since it is d.c. the current through the capacitor is in one direction only. So what will happen to the charge on the capacitor as time increases? And after a long enough time has passed, what will happen then?
@dr2453, the voltage between battery terminals is constant, so current cannot flow across the capacitor. This is because the capacitor's plates are separated by a dielectric film or air, only a changing electric field (voltage) would make the current pass through it.
So, if a resistor it's added in series, no current would flow through it, and the capacitor would be directly connected to the battery, as if the resistor wasn't there. The same goes if the resistor is added in parallel, the capacitor is still directly connected to the battery and nothing changes.
@BruceW, I'm sure this problem isn't about transitory response, so there's no need to involve time. However, in that case the charge will increase exponentially with time, until it reaches the value Q= C*V, where C is the capacitance and V is the voltage of the battery.
