Independent components of tensor
cscott
For indices running from 0-3:
R_{iklm} = -R_{kilm} = -R_{ikml}
With the above conditions how do I know the number of independent component is reduced from 4^4 = 256 to 36.
No idea how to figure this out.
When in doubt, look at a simpler case. If you know that R_{ij}= -R{ji}, then knowing R_{ij} for i< k immediately gives you the value of R_{ji}: Of the 16 possible values of R_{ij}, there are 4 with i= j so 16- 4= 12 where i is not equal to j and so 12/2= 6 where i< j. Knowing those 6 tells you the other 6. Further, if i= j then R_{ii}= -R_{ii} so that must be 0: The 4 "diagonal" terms must be 0. You can choose 6 of the possible 16 terms of R<sub>ij</sub>.
Now, for this problem you know that R_{iklm} = -R_{kilm}[/itex]. Of the 44= 256 terms, how many have i< k? Knowing that many automatically gives you an equal number. How many have i= k? You know those are 0.
You also know R_{iklm}= -R_{ikml}. Do the same thing with m and l.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
