Undergrad Index Notation for Lorentz Transformation
The discussion focuses on the proper use of index notation in the context of Lorentz transformations and their transposes. It clarifies that the transpose of a Lorentz transformation matrix, written as (ΛT)μν, should be expressed as Λνμ, which involves flipping both the indices' positions and their types (raised to lowered). The confusion arises from the distinction between matrix transposition and the manipulation of tensor indices, emphasizing that the transpose must respect the dual nature of the spaces involved. The correct relationship between the Lorentz transformation and its inverse is established, highlighting that the inverse is not simply the transpose but involves the metric tensor. Understanding these nuances is crucial for correctly applying Lorentz transformations in physics.
fayled
The Lorentz transformation matrix may be written in index form as Λμ ν. The transpose may be written (ΛT)μ νν μ.
I want to apply this to convert the defining relation for a Lorentz transformation η=ΛTηΛ into index form. We have
ηρσ=(ΛT)ρ μημνΛν σ
The next step to obtain the correct result seems to be to write (ΛT)ρ μμ ρ
However I don't see how this agrees with the way I have defined the transpose above. Why can we not use (ΛT)ρ μμ ρ, which seems to follow from the definition of the transpose above?
Thanks for any help!
ηρσ=(ΛT)ρ μημνΛν σ
The word "transpose" is appropriate for matrices, not tensors. For matrices, the distinction between raised indices and lowered indices is more confusing than helpful. So let's write it all in terms of raised indices. Then the Lorentz transform is:
\Lambda^{\alpha \beta} x^\beta = (x')^\alpha
(\Lambda^T)^{\alpha \beta} = \Lambda^{\beta \alpha}
So the defining relation for \eta is:
(\Lambda^T) \eta \Lambda = \eta
or in terms of components:
\Lambda^{\beta \alpha} \eta^{\beta \mu} \Lambda^{\mu \nu} = \eta^{\alpha \nu}
Thanks for your reply.
Unfortunately I think this just sidetracks the problem. I really need to be able to understand how to deal with the raising and lowering of indices.
For example, I want to be able to understand why the condition Λνμ=(Λ-1)μν doesn't imply that ΛΛT=I. If I just use all indices as raised, then that doesn't seem to help.
To be honest, things such as ##(\Lambda^T)^\alpha{}_{\beta}## do not really make sense - the indices are in the wrong place in relation to the transpose and the parenthesis. You can define a matrix
\Lambda = (\Lambda^\alpha{}_{\beta})
which is the matrix whose entry in row ##\alpha## and column ##\beta## is ##\Lambda^\alpha{}_\beta##. By definition of matrix transposition, the transpose ##\Lambda^T## would then be the matrix
(\Lambda^\alpha{}_\beta)^T
with ##\Lambda^\alpha{}_\beta## being the entry in column ##\alpha## and row ##\beta##. If you anyway insist on writing things such as ##(\Lambda^T)_\beta{}^\alpha##, the only meaningful relation involving indices up and down would be ##(\Lambda^T)_\beta{}^\alpha = \Lambda^\alpha{}_\beta##. You cannot change where the indices are located (i.e., up/down).
Edit: That being said, I strongly discourage thinking of the Lorentz transformation as a matrix. You can represent it by a matrix, but really the most intuitive way of thinking about it is as ##\Lambda^\alpha{}_\beta = \partial x'^\alpha/\partial x^\beta## (this will also help in making the transition to general coordinate transforms).
Ok, well in some places I seem to be reading that transposing involves swapping the indices left-right, whereas in other places it seems to imply the indices are completely swapped left-right and top-bottom.
So, assuming we swap left-right only, would you be able to help identify why the following is incorrect (which has led me to all this confusion)?
We know that
Λνμ=(Λ-1)μν
So, why can't I just swap the indices left-right on the left hand side term, to give
T)μν=(Λ-1)μν
which would then imply in matrix form
ΛT-1
This is obviously not correct, because the Lorentz group actually satisfies η=ΛTηΛ...
fayled said:
We know that
Λνμ=(Λ-1)μν.
This is incorrect. Here you need to swap the indices from up to down - you do that with the metric tensor. Another reason to avoid matrix notation completely.
See for example Equation 1.34 here:
http://epx.phys.tohoku.ac.jp/~yhitoshi/particleweb/ptest-1.pdf
Well, it isn't true that (\Lambda^{-1})^\mu_\nu = \Lambda^\nu_\mu. Let's just look at 2-D spacetime. Then
\Lambda = \left( \begin{array} \\ \gamma & - \gamma v/c\\ -\gamma v/c & \gamma \end{array} \right)
where \gamma = \frac{1}{\sqrt{1 - \frac{v^2}{c^2}}}
\Lambda^{-1} = \left( \begin{array} \\ \gamma & + \gamma v/c \\ +\gamma v/c & \gamma \end{array} \right)
\Lambda^T = \left( \begin{array} \\ \gamma & - \gamma v/c \\ -\gamma v/c & \gamma \end{array} \right)
\eta = \left( \begin{array} \\ 1 & 0 \\ -1 & 0 \end{array} \right)
So it's not true that \Lambda \Lambda^T = I.
@fayled :
1) Have a look at this recent thread in which I learned the error of my ways regarding transposition and index placement. See especially post #14 in that thread.
2) tl:dr : In taking a transpose, one must indeed flip upstairs##\leftrightarrow##downstairs as well as swapping the index symbols. See the end of post #14 in the above thread.
Re-summarizing, if ##V,W## are vector spaces, and ##L## is a linear map: $$L : V \to W $$then the transpose ##L^T## is defined as $$L^T : W^* \to V^* ~,$$whereas the inverse is $$L^{-1} : W \to V ~.$$ That's why it's correct to do an upstairs##\leftrightarrow##downstairs flip when taking the transpose -- because you're now working with the dual spaces.
(##V^*## denotes the dual space of ##V##.)
By definition a Lorentz transformation matrix obeys
$$\eta_{\mu \nu} {\Lambda^{\mu}}_{\rho} {\Lambda^{\nu}}_{\sigma}=\eta_{\rho \sigma},$$
where (in the "west-coast convention") ##(\eta_{\mu \nu})=\text{diag}(1,-1,-1,-1)##. Note that it is crucial to keep the indices in clear order, both horizontally and vertically.
Sometimes the matrix-vector calculus is shortening some calculations, but there's big confusion in the literature and of course also here in this forum. We had a recent thread about it somewhere here in the relativity subforum. The upshot is that by definition
$${(\Lambda^T)^{\mu}}_{\nu}={\Lambda^{\nu}}_{\mu}.$$
With this notation, putting ##(\eta_{\mu \nu})=\hat{\eta}## and ##({\Lambda^{\mu}}_{\nu})=\hat{\Lambda}## (which btw. makes the shortcoming of the matrix-vector notation apparent, because the "automatic syntax check" that co- and contravariant indices are not longer clearly distinguished as in the Ricci calculus, where the former are lower and the latter are upper indices) you can write the above "pseudo-orthogonality condition" as
$$\hat{\Lambda}^T \hat{\eta} \hat{\Lambda}=\hat{\eta},$$
which, because of ##\hat{\eta}^2=\hat{1}##, implies
$$\hat{\Lambda}^{-1}=\hat{\eta} \hat{\Lambda}^T \hat{\eta}.$$
This is easily translated back into index notation
$${(\Lambda^{-1})^{\mu}}_{\nu} = \eta^{\mu \rho} \eta_{\nu \sigma} {\Lambda^{\sigma}}_{\rho}={\Lambda_{\nu}}^{\mu},$$
i.e., the inverse LT is not simply given by the transverse matrix but the indices must be dragged by the pseudo-metric matrix too.
ηρσ=(ΛT)ρ μημνΛν σ
The usual confusion again!
1) The non-covariant expression (\Lambda^{T})^{\mu}{}_{\nu} = \Lambda^{\nu}{}_{\mu}, can only be used for the concrete elements of \Lambda, for example: \Lambda^{1}{}_{2} = (\Lambda^{T})^{2}{}_{1}.
2) When \Lambda^{T} comes multiplied by other matrices, don’t use any up-down index structure for \Lambda^{T}. See (3).
3) To obtain the index structure of the matrix equation \eta = \Lambda^{T} \ \eta \ \Lambda, do the following: Since \eta^{T} = \eta, i.e., \eta_{\alpha\beta} = \eta_{\beta\alpha}, then \eta_{\alpha\beta} = \left( ( \eta \ \Lambda)^{T} \ \Lambda \right)_{\beta\alpha} . Now, if we choose the matrix element of \Lambda to be of the form \Lambda^{\rho}{}_{\sigma} with upper index represents the rows and the lower one for columns, then the above equation becomes \eta_{\alpha\beta} = ( \eta \ \Lambda)^{T}_{\beta\mu} \ \Lambda^{\mu}{}_{\alpha} . \ \ \ \ \ \ \ \ (3) For any matrix M, the transpose M^{T} is defined by M^{T}_{ab} = M_{ba}. Thus, (\eta \ \Lambda)^{T}_{\beta\mu} = (\eta \ \Lambda)_{\mu\beta}, and Eq(3) becomes the one we know \eta_{\alpha\beta} = (\eta \ \Lambda)_{\mu\beta} \ \Lambda^{\mu}{}_{\alpha} = \eta_{\mu\nu} \ \Lambda^{\nu}{}_{\beta} \ \Lambda^{\mu}{}_{\alpha} .
4) The expression (\Lambda^{-1})^{\sigma}{}_{\rho} = \Lambda_{\rho}{}^{\sigma} , \ \ \ \ \ \ \ \ \ \ \ (4’) is an allowed covariant expression because you can lower and raise the indices on \Lambda by \eta and \eta^{-1} respectively: \Lambda_{\rho}{}^{\sigma} = \eta^{\sigma \nu} \ \eta_{\rho\mu} \ \Lambda^{\mu}{}_{\nu} . \ \ \ \ \ \ \ \ \ (4) Substituting (4’) in the LHS of (4), we find (\Lambda^{-1})^{\sigma}{}_{\rho} = \eta^{\sigma \nu} \ \left( \eta_{\rho\mu} \ \Lambda^{\mu}{}_{\nu} \right) = \eta^{\sigma \nu} \ \left( \eta \ \Lambda \right)_{\rho \nu} . \ \ \ \ (5) This can be rewritten as (\Lambda^{-1})^{\sigma}{}_{\rho} = \eta^{\sigma\nu} \ \left(\eta \ \Lambda \right)^{T}_{\nu \rho} = \left( \eta \ ( \eta \ \Lambda)^{T} \ \right)^{\sigma}{}_{\rho} .
And, therefore, we have the correct matrix equations \Lambda^{-1} = \eta \ \Lambda^{T} \ \eta = \left( \eta \ \Lambda \ \eta \right)^{T} , \ \ \ \ \ \ (6) and \Lambda^{T} = \eta \ \Lambda^{-1} \ \eta = \left( \eta \ \Lambda \ \eta \right)^{-1} . \ \ \ \ \ \ (7)
5) The matrix \Lambda^{-1} can be constructed either from its elements as given by Eq(5), or directly by simple matrix multiplication as given by Eq(6). To check that I did not make a mistake, let us do them both. We write (5) as (\Lambda^{-1})^{\sigma}{}_{\rho} = \eta_{\mu\rho} \ \Lambda^{\mu}{}_{\nu} \ \eta^{\nu\sigma} , and evaluate the relevant matrix elements using the fact that \eta = \eta^{-1} = \mbox{diag} (1, -1, -1, -1):
(\Lambda^{-1})^{0}{}_{k} = (-1) \ \Lambda^{k}{}_{0} \ (+1) = - \Lambda^{k}{}_{0} . In other words, we have the following equalities (\Lambda^{-1})^{0}{}_{k} = \Lambda_{k}{}^{0} = - \Lambda^{k}{}_{0} = - (\Lambda^{T})^{0}{}_{k} .
Next, we calculate the space-space matrix elements (\Lambda^{-1})^{i}{}_{k} = \eta_{\mu k} \ \Lambda^{\mu}{}_{\nu} \ \eta^{\nu i} = (-1) \ \Lambda^{k}{}_{i} \ (-1) . Thus (\Lambda^{-1})^{i}{}_{k} = \Lambda_{k}{}^{i} = \Lambda^{k}{}_{i} = (\Lambda^{T})^{i}{}_{k} . And similarly, we find (\Lambda^{-1})^{k}{}_{0} = \Lambda_{0}{}^{k} = - \Lambda^{0}{}_{k} = - (\Lambda^{T})^{k}{}_{0} .
From these matrix elements, we can write
\Lambda^{-1} = \begin{pmatrix}<br /> <br /> \Lambda^{0}{}_{0} &amp; -\Lambda^{1}{}_{0} &amp; -\Lambda^{2}{}_{0} &amp; -\Lambda^{3}{}_{0} \\<br /> <br /> -\Lambda^{0}{}_{1} &amp; \Lambda^{1}{}_{1} &amp; \Lambda^{2}{}_{1} &amp; \Lambda^{3}{}_{1} \\<br /> <br /> -\Lambda^{0}{}_{2} &amp; \Lambda^{1}{}_{2} &amp; \Lambda^{2}{}_{2} &amp; \Lambda^{3}{}_{2} \\<br /> <br /> -\Lambda^{0}{}_{3} &amp; \Lambda^{1}{}_{3} &amp; \Lambda^{2}{}_{3} &amp; \Lambda^{3}{}_{3}<br /> <br /> \end{pmatrix} . \ \ \ (8)
Indeed, the same matrix can be obtained from Eq(6) as follow: From
\Lambda = \begin{pmatrix}<br /> \Lambda^{0}{}_{0} &amp; \Lambda^{0}{}_{1} &amp; \Lambda^{0}{}_{2} &amp; \Lambda^{0}{}_{3} \\<br /> \Lambda^{1}{}_{0} &amp; \Lambda^{1}{}_{1} &amp; \Lambda^{1}{}_{2} &amp; \Lambda^{1}{}_{3} \\<br /> \Lambda^{2}{}_{0} &amp; \Lambda^{2}{}_{1} &amp; \Lambda^{2}{}_{2} &amp; \Lambda^{2}{}_{3} \\<br /> \Lambda^{3}{}_{0} &amp; \Lambda^{3}{}_{1} &amp; \Lambda^{3}{}_{2} &amp; \Lambda^{3}{}_{3} \end{pmatrix} ,
and
\eta = \begin{pmatrix}<br /> 1 &amp; 0 &amp; 0 &amp; 0 \\<br /> 0 &amp; -1 &amp; 0 &amp; 0 \\<br /> 0 &amp; 0 &amp; -1&amp; 0 \\<br /> 0 &amp; 0 &amp; 0 &amp; -1 \end{pmatrix} ,
We fined
\eta \ \Lambda \ \eta = \begin{pmatrix}<br /> \Lambda^{0}{}_{0} &amp; -\Lambda^{0}{}_{1} &amp; -\Lambda^{0}{}_{2} &amp; -\Lambda^{0}{}_{3} \\<br /> -\Lambda^{1}{}_{0} &amp; \Lambda^{1}{}_{1} &amp; \Lambda^{1}{}_{2} &amp; \Lambda^{1}{}_{3} \\<br /> -\Lambda^{2}{}_{0} &amp; \Lambda^{2}{}_{1} &amp; \Lambda^{2}{}_{2} &amp; \Lambda^{2}{}_{3} \\<br /> -\Lambda^{3}{}_{0} &amp; \Lambda^{3}{}_{1} &amp; \Lambda^{3}{}_{2} &amp; \Lambda^{3}{}_{3}<br /> \end{pmatrix} . \ \ \ (9)
Clearly, you obtain Eq(8) by taking the transpose of Eq(9).
6) Here is an exercise for you (probably the most important thing you should do). Use the matrix \eta \ \Lambda \ \eta, as given in Eq(9), to show that (\eta \ \Lambda \ \eta) \Lambda^{T} = I_{4 \times 4} .
Likes vanhees71
If this is your goal then I would recommend not trying to mix tensor and matrix notation. Focus entirely on the raising and lowering tensor indices, and drop the matrix and matrix transposition stuff entirely.
IMO, the best approach will be to take 2D tensors and expand them out explicitly writing the sums.
Likes vanhees71 and Orodruin
  • · Replies 30 ·
