Induced Current in Square Loop
A square loop with a resistance of 0.12 Ω and dimensions of 21cm x 21cm is subject to a time-varying magnetic field described by B=4t−2t^2. At t=0.0s, the magnetic field is zero, leading to an initial current of 0 A, which is confirmed through calculations. To find the current at t=1.0s, Faraday's law of electromagnetic induction is applied, specifically using the equation V = -A*(dB/dt) and then V = IR to determine the current. The discussion emphasizes the correct application of these equations to solve for induced current in the loop. Understanding these principles is crucial for accurately determining the current at different time intervals.
qlzlahs
A 21cm×21cm square loop has a resistance of 0.12 Ω . A magnetic field perpendicular to the loop is B=4t−2t^2, where B is in tesla and t is in seconds.
(A) What is the current in the loop at t=0.0s?
(B) What is the current in the loop at t=1.0s?
for a square loop, B = (√2)(μ_0*I)/(π*R), where R is the length of the side
(A) I assumed that at t = 0, B = 4(0) - 2(0^2) = 0.
0 = (√2)(μ_0*I)/(π*.21), but that means I = 0 A and that didn't work.
Help please? Thanks.
You must use Faraday's law of electromagnetic induction.
Likes qlzlahs
So I use V = -A*(dB/dt), then use V = IR to find the current?
Correct..
Likes qlzlahs
