Induced secondary coil flux field?
The discussion centers on the interaction between a permanent magnet (PM) and two coupled coils. It clarifies that waving a magnet in front of a primary coil does not generate a field equal to the PM's strength, as the induced secondary flux is dependent on the current generated in the primary coil. The secondary coil, while independent, will experience induced current due to the primary coil's changing flux. The strength of the PM array influences the primary coil's magnetic field, and the changing flux affects the primary coil's strength. Overall, the relationship between the coils and the PM is complex and involves various electromagnetic principles.
Robin07
Using a PMs' field and inducing a primary coil which is coupled with an independent coil of equal configuration to the primary. Would this secondary flux field be opposite and of equal EMForce? If so, Equal to the PMs' strength or the primarys' EMForce?
Thanks Robin07
Thanks Robin07
Took me a bit to figure out that PM is permanent magnet. Got it now. No, waving a magnet in front of a coil that is connected to another separate coil will not generate a field that is equal to the permanent magnet's field. The changing flux in the first coil will generate a voltage in that coil, which generates a current in the winding wire, which flows through the second coil, which generates the secondary flux. The two coil fluxes are equal, since the currents are equal (assuming equal turns), but that's not equal to the full power of the magnet.
Sorry about the PM thing. Perhaps I should clarify a little. The PM is a cylindercal/ring Halback array going at 3400rpm - 6400rpm as well as crossing the primary coils' path where the coil is at its greatest diameter(voltage unknown at this time) bisecting it at a right angle. The secondary coil is not connected to the primary, it is independent but is located within the flux field of the primary. The secondary coil should realize a current...Yes? And yes, let's agree that the coils are of equal build.
Does the strength in the PM array play a role in the strength of the induced primary coils' magnetic field. And does the amount of changing flux that is going through the wire strengthen and weaken the primary coil flux field?
Thanks Robin07
If we connect an electrical active load to secondary winding, the mechanical primary part (as you have named "PM") fronts the resistance momentum. If not, it just be supplied the power loss of system.
Creative thinking is enjoyable, Then think about your surrounding things and other thought products. http://electrical-riddles.com
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
