Inductive Effect: Understand N+I and -I Effects
  • Thread starter Thread starter pink_ele
The inductive effect refers to the influence of electronegative atoms on the acidity of molecules, particularly in relation to A-H bonds. It is categorized into the positive inductive effect (+I) and negative inductive effect (-I). The +I effect occurs when groups like alkyl chains push electron density towards adjacent atoms, stabilizing positive charges and making the molecule less unstable. Conversely, the -I effect involves electronegative atoms pulling electron density away, which can destabilize cationic acids by concentrating charge on one atom, thus favoring proton loss. This stabilization of the conjugate base enhances the strength of the conjugate acid, as anything that stabilizes the conjugate base increases acidity. The inductive effect also plays a significant role in reaction mechanisms, such as determining the site of addition in electrophilic reactions, where the stability of intermediates influences the preferred reaction pathway. Understanding these effects is crucial for solving reasoning questions related to acid-base chemistry and reaction mechanisms.
pink_ele
i havnt understood anything about inductive effect,please explain me this n +I effect and
-I effect
many reasoning questions are based on this topic and i fail to get any marks in them
Chemistry news on Phys.org
The inductive effect is when an electronegative atom/s in close proximity to an A-H bond makes a molecule more acidic then its counterpart lacking the electronegative atoms. Remember that the loss of a proton is an equilibrium process. Anything that makes the conjugate base more stable makes the conjugate acid stronger. Anything that destablizes the acid also makes it more acidic.
In acids which lose a proton to form an anion, this effect is primarily due to the stabilization of the conjugate base. The electronegative atom causes a slight delocalization of the negative charge. Anything that delocalizes charge makes a molecule more stable.
In cationic acids, the electronegative atom destabilizes the acid by drawing in electron density and concentrating the charge even further onto one atom. This pushes the equilibrium (relatively) in favor of proton loss.
The most basic way to explain it is that the inductive effect is used to explain how certain groups can "Push" and "Pull" charge that is next to them, the most common example is the Methyl (or similar alkyl group) that will "Push" negative charge from itself and toward whatever it is attatched to, this is called a "+I" group because of this effect. The pushing of negative charge towards something that is positive will help make that species a little less positive then if it was all alone and therefore less unstable.
This also applied to elminination and addition reactions, In early chemistry you may have done the addition of Br_{2} to an alkene such as Propene, although at higher levels this is described more eliquently with anti additions and such if you use the mechanism that a Br "Adds" to one of the carbons on either side of the double bond, and leaves a positive charge on the other carbon then the inductive effect plays a role in determining the most preferred place for that first Br atom to add (The least substituted place, so the inductive effect pushes charge onto the cation)
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
