Inductive Heater Homework: Find Current & Rate of Energy
  • Thread starter Thread starter Angie K.
    Heater
The discussion revolves around calculating the current and rate of thermal energy produced in a coil of copper wire subjected to a changing magnetic field. The user initially calculated the magnetic flux and resistance but encountered errors in their formulas and assumptions regarding the geometry of the coil and wire. They clarified that the correct relationship for current involves electromotive force (emf) rather than magnetic flux directly. The area of the wire's cross-section and the total length of the wire were also points of confusion, impacting the resistance calculation. The user seeks assistance in identifying and correcting their mistakes to arrive at the correct answers.
Angie K.
A 34.6 -cm-diameter coil consists of 25 turns of circular copper wire 2.25 mm in diameter. A uniform magnetic field, perpendicular to the plane of the coil, changes at a rate of 3.55 × 10-3T/s. Determine
a. the current I in the loop,
b. and the rate dU/dt at which thermal energy is produced.
magnetic flux = B*A cos Theta
I = magnetic flux / R
R = p (L/A) where p is the resistivity of copper
Here is what I attempted:
First, I found the magnetic flux by using the formula: B*A cos Theta
multiplying the area by 25 because it's in a coil and using .173 meters for the radius of the coil
(3.55*10^-3)(25*.173) = 1.535375*10^-2
then to find I (current) :
I = magnetic flux / resistance
I calculated resistance by :
since it's a coil, I multiplied the L by 25 and the A by 25
R = p (L/A) = 1.68*10^-8 (25*pi*.173 / 25*pi*1.125*10^-2)^2 = 0.001148
plugging in that into the I equation, I = 1.535375e-2 / 0.001148 = 13.374 A
This isn't the right answer and I messed something up. I would appreciate if someone could help me with catching my mistake! I appreciate it!
Thanks in advance!
again. why do you say that i=magnetic flux/R ?
##E=-d\phi/dt##.
so i is the change in magnetic flux per unit time/R.
what is the area of cross section of wire?
##E=-d\phi/dt##.
I meant to say that i = emf/R
The area of the cross section is pi*r^2 which is pi(.00225)^2 where .00225 is the radius of the wire
= 1.590431e-5
Would I only multiply the circumference of the coil by 25?
no. 2.25 is its diameter.
Oh that's right! My bad.
R = p (L/A) = 1.68*10^-8 (25*pi*.173 / pi*(0.00225/2)^2 = .11482
then I = Emf/R = B*Area of coil / R = 3.41194*10^-2 / .11482 = 0.297155 A
Still not getting it right. When calculating for the Emf, did I do that right? or is the fact that i's a changing magnetic field need some different calculation to get the Emf?
what is the total length of wire? your value of L in R=p(LA) is wrong.
