Inelastic Buckling/Buckling in short columns
Calculating the buckling force for short columns involves understanding the material properties, loading conditions, support types, effective buckling length, and slenderness ratios. While global elastic buckling theory is not applicable for short columns, the Johnson equation can be used for inelastic buckling scenarios where the material has yielded. The Johnson formula incorporates the compressive yield strength and requires a factor of safety to ensure peak stress remains below yield strength. It is essential to use the modulus of elasticity rather than the tangent modulus in this context. Therefore, investigating buckling in short column scenarios is valid and can provide useful insights.
roanoar
Hey I was wondering how you're supposed to calculate the buckling force for a short column. Is there even a way? If there is, is it accurate and how do you use it? And finally how do you know when to use it?
If the column is "short" (below slenderness ratio limit) there is no global elastic buckling before the material yields, so global elastic buckling theory will not be useful for predicting material failure.
To verify whether a column is "short" or not, you must know the material, how it is being loaded, how it's being supported (fixed, fixed-fixed, pinned-fixed, pinned-guided...), the effective buckling length, the least section's radius of gyration and the limiting slenderness ratio for your beam-column in the design code you are working with.
That's interesting so I guess I shouldn't be looking at buckling for these short scenarios. I have calculated all the things you mentioned and have verified it is short. I was simply looking at buckling originally because I came across something called Johnson's equation which supposedly can solve buckling for short beams. But it requires a tangent modulus and this threw me off.
Most engineering designs are within the elastic limit and Euler's critical buckling load is included here. Johnson's approach applies to inelastic buckling, where the material already yielded with little strain or shows no significant elastic behaviour, hence the need for the tangent modulus.
roanoar said:
So I guess I shouldn't be looking at buckling for these short column scenarios.
You should be looking at buckling. You were right to look at that.
The Johnson formula applies to short columns. Notice the peak stress in the Johnson formula is the compressive yield strength, Scy. Hence, the Johnson formula prevents inelastic behavior. Furthermore, you divide the Johnson formula by a factor of safety, making the peak stress below the yield strength. Also, the Johnson formula uses modulus of elasticity, not tangent modulus.
nvn is right, you can apply Johnson's approach to short columns, but it is not limited to this condition.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
