Inelastic Collision and Finding Initial Velocity
The discussion revolves around an inelastic collision problem involving two rolling gold balls of equal mass. One ball has an initial velocity of 2.70 m/s, and after the collision, the velocities of the balls are given in terms of direction and magnitude. The goal is to determine the magnitude and direction of the unknown initial velocity.
  • Participants discuss the conservation of momentum and the need to analyze the components of the velocities. There are attempts to clarify how to incorporate these components into the momentum equation. Questions arise about the proper use of vector addition and the implications of the drawn vector diagram.
Participants are actively engaging with the problem, with some providing guidance on using vector diagrams and momentum conservation. There is a recognition of the need to carefully manage the signs of the components, but no consensus has been reached on the next steps to take with the components.
One participant mentions a similar problem involving a railroad car collision, indicating that there may be varying levels of familiarity with the concepts among participants. The original poster expresses uncertainty about how to proceed after obtaining the components of the velocities.
pitaaa
Two rolling gold balls of the same mass collide. The velocity of one ball is initially 2.70 m/s [E]. After the collision, the velocities of the balls are 2.49 m/s [62.8 degrees N of W] and 2.37 m/s [69.2 degrees S of E]. What are the magnitude and direction of the unknown initial velocity?
mv1 + mv2 = mv1' + mv2'
First off, I drew the resulting velocities, and found their components.
The x and y components of the 2.49 m/s velocity are -2.49cos62.8 and 2.49sin62.8 respectively. The x and y components of the 2.37 velocity are 2.37 cos 69.2, and -2.37sin69.2 respectively. Knowing this, I figure I have to incorporate the components somewhere into the equation - I just don't know where! Given the above equation, since the masses are equal, I can eliminate the masses from the equation entirely - likewise, I can eliminate the 1/2, by multiplying the entire equation by two - thus, I have a simplified equation ... I just don't know where to go from here. Can anybody give me a hint as to what to do with the components? Any insight is greatly appreciated!
The answer is supposed to be 3.00 m/s, for the initial velocity of the unknown.
Your inelastic collision will result in the conservation of momentum. Total before is total after as you have given.
Draw a careful vector diagram. Note that you can use vector addition by adding the x and y components separately and still insure that Total momentum before is the same as Total momentum after in each axis.
A careful diagram will help you keep the signs of the values straight.
Okay, I redrew the vector diagram.
But what do I do once I have my components? :/
I don't know what to do with them.
Doesn't the sum of the x components of the velocity vectors (you've discarded mass as both are the same, but momentum vectors if you were still carrying the mass) before properly add to the sum of the after collision velocity (or momentum) components? The same for the y components?
Hmm I'll try it :/ Unless my diagram is totally wrong :P
i kinda have a proble like that but in mine i have a 5,000 kg railroad car moving at 2 m/s collides and connects to another identical car intially at rest.what is the finial velocity of the two connected train cars?
  • · Replies 22 ·
  • · Replies 29 ·
