Calculating Speed of Toyota After Collision with Cadillac
  • Thread starter Thread starter 7tongc5
    Collision Speed
To calculate the speed of a Toyota after colliding with a stationary Cadillac, the problem involves two phases: the collision and the subsequent motion under friction. The conservation of linear momentum is applied to find the combined velocity after the collision, while the force of friction is used to determine the deceleration during the skid. The calculations yield a friction force of 12,544 N, leading to a deceleration of -3.92 m/s² over a distance of 2.8 m. The initial velocity of the wreck is calculated to be approximately 14.99 m/s, but the expected answer is 20 m/s, indicating a discrepancy in the calculations. The discussion emphasizes the importance of correctly applying physics principles to solve the problem.
7tongc5
A 1000kg toyota collides into a 2200kg Cadillac at rest. The bumpers lock, the brakes are locked, and the two cars skid forward 2.8m before stopping. The coefficient of friction btwn tires and road = .4 ... what was the speed of the toyota at impact?
I don't know how to start it off (i don't know how i should set up equations while taking friction into account).
Any hints would be helpful. Thanks. :)
You should consider the problem as two separate process. The first is collision. It happens in such a very short time that both cars stay at the same place where they were just before the collision process. After the collision went on, both cars move with the same velocity. This velocity is determined by the law of conservation of linear momentum.
The second process is motion under the effect of friction. The wreck of the cars moves as a single body of mass 2200 kg + 1000 kg. You can calculate the force of friction, the deceleration due to friction, the displacement, the final velocity whis is zero, so you can figure out the initial velocity of the wreck. From that you get the initial momentum of the wreck which is equal to the initial momentum of the toyota as the cadillac had been in rest. From this momentum, dividing it by the mass of the toyota you get the velocity of the toyota before collision.
ehild
it's totally awesome that you laid out the steps, but i still managed to screw it up somehow: the answer's supposed to be 20 m/s
1) force of friction = .4(3200)(9.8) = 12,544
2) F = ma
12544 = 3200a --> a = -3.92 m/s2
3) v = v<initial>^2 + 2(-3.92)(2.8)
21.952 = v<initial> ^2
4.69 m/s = v<initial>
4) total momentum of wreck = 4.69 (3200) = 14992.948
4) 14992.948 = m<toyota> x v
v = 14.99 m/s
really appreciate your help, 7tongc5
v = 14.99 m/s
I got the same result as you.
ehild
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
