Inequalities, trigonometric and x exponent.
Mutaja
These are the two last problems I'll bother you with for a short while (I love this forum, I'll definitely stay on and hopefully be able to contribute in the future).
Problem 1:
(##-x^2##-1)sin2x > 0 , xe[0,2\pi]
Problem 2:
##2^{-x^2+x+2}## < 4
For the first problem:
Since x is an element within a positive boundary, can I write the problem as:
sin(2x) ≤ 0
Why, or why not?
Other than that, I need to refresh my knowledge on solving inequalities.
Any help or input is appreciated while I attempt to gather more info.
Problem 1:
Problem 2:
sin(2x) ≤ 0
Why, or why not?
Your first inequality can be rewritten as -(x2 + 1)sin(2x) ≥ 0, or
(x2 + 1)sin(2x) ≤ 0
Since x2 + 1 ≥ 1 for all real x, it can never be zero or negative. If you divide both sides of the inequality by x2 + 1, and the direction of the inequality won't change. That gets you to the inequality you wrote.
BTW, your mix of LaTeX and HTML tags threw me off for a bit. In LaTeX use leq for ≤. Using the U (underscore) HTML tag under a < symbol confused me for a bit.
You can also click Go Advanced to see a table of quick symbols off to the right. It has Greek letters and symbols such as ≤, ≥, ≠, ∞, and several others.
(x2 + 1)sin(2x) ≤ 0
But how do I go from sin2x ≤ 0 to something like x = \pi + n \pi/2? This is just something random I wrote down, but hopefully you get the idea.
Where do I even look to find the solution for this?
Also, in respect to my 2nd inequality. I don't know where I should look for tips on how to solve it. My book says absolutely nothing about inequality in this regard. It might sound lazy, but I've looked. I suspect I'm supposed to remember this from pre-calculus math but it's as unfortunate as it's obvious - I don't.
Sorry I'm not able to make more progress before posting again. Again, thanks for all your help and any input is greatly appreciated.
I'm sorry, I didn't know it mattered as I can't see any visual difference, but I'll keep that in mind. Thanks.
You're not going to get x = ... as the solution to sin(2x) ≤ 0. The simplest way is to sketch a quick graph of y = sin(2x) and note the intervals where the graph touches or goes below the x-axis.
For your second problem, which is
$$2^{-x^2 + x + 2} < 4$$
Note the 4 = 22, so then you have
$$2^{-x^2 + x + 2} < 2^2$$
Since y = 2x is a strictly increasing function, if 2A < 2B, then A < B.
This was in reference to what I said about using the canned symbols ≤ rather than [ U]<[/ U]; i.e., coming up with your own way to write ≤. A lot of us here at PF will "quote" your post, which means that we're looking at the LaTeX and/or HTML markup, instead of how the post actually appears in the browser, so your ≤ actually seemed to me at first to be <, which was why I was confused.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
