Proving cos2(x)/(n2 + 1) ≤ 1/(n2 + 1) - Proof and Reasoning
  • Thread starter Thread starter Miike012
    Inequality
Miike012
I want to prove
I know this is an obvious inequality but I want to know if my reasoning is correct.
For the expression cos2(x)/(n2 + 1) to be as large as possible the numerator must → ∞ but cos2(x) is bounded above by 1.
cos2(x) = 1 for x = 2∏k where k ≥1 is an integer.
cos2(2∏k)/((2∏k)2 + 1) = 1/ ((2∏k)2 + 1) for integers k ≥ 1.
Now I want to compare n2 + 1 to (2∏k)2 + 1:
n2 ≤ (2∏k)2 where n and k are consecutive integers from 1 to ∞.
n2 + 1 ≤ (2∏k)2 + 1
and
1/(n2 + 1) ≥ 1/ ((2∏k)2 + 1 )
so cos2(x)/(n2 + 1) ≤ 1/(n2 + 1)
This is unnecessarily complicated, if you can assume the identity (cos(x))^2 ≤ 1, then just divide both sides by (n^2 + 1)
Yes I know that, I just wanted to see if I was correct in what I was saying.
Miike012 said:
I want to prove
The numerator can't approach infinity
Do you mean that if n = 2, k = 3, and if n = 3, k = 4? I get the idea that what you said isn't what you meant.
Miike012 said:
n2 + 1 ≤ (2∏k)2 + 1
and
As already noted by poopsilon, what you have is much more complicated than what is needed, not to mention unclear. For any integer n (and for that matter any real number), -1 ≤ cos2(n) ≤ 1. This idea and the "squeeze" theorem are all you need to establish the inequality you started with.
Mark44
"The numerator can't approach infinity"
Miike012
I know this that is why I said...
" but cos^2(x) is bounded above by 1."
Mark44
"Do you mean that if n = 2, k = 3, and if n = 3, k = 4? I get the idea that what you said isn't what you meant."
Miike012
"where n and k are consecutive integers from 1 to ∞."
So if I have the following inequality
n^2 ≤ (2∏k)^2
Then if n and k are consecutive integers from 1 to ∞ what I am meaning to say is...
when n is 1 k is 1
when n is 2 k is 2
n = 3, k = 3...
so,
(1)^2 ≤ (2∏(1))^2
(2)^2 ≤ (2∏(2))^2
(3)^2 ≤ (2∏(3))^2
And so on...
Miike012 said:
Miike012
n^2 ≤ (2∏k)^2
when n is 1 k is 1
when n is 2 k is 2
n = 3, k = 3...
Since n and k are equal at each step, there's no need for two variables. What you wrote was very confusing. You could have said
n2 ≤ (2##\pi n)^2##, for n = 1, 2, 3, ...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
