Inertial load model penetration
In the discussion about an FEA model experiencing penetration issues, the user seeks advice on preventing heavy parts from penetrating softer ones while applying inertial loads. Suggestions include reviewing contact conditions, as improper definitions may lead to unrealistic penetrations. Display scaling in ANSYS can exaggerate perceived deformations, complicating the analysis. Recommendations also involve uniting bonded parts into a single parasolid for better results. Properly redefining contact conditions and examining loading and boundary conditions are crucial for resolving the issue.
spider80
Hi,
I have an FEA model where all my parts are bonded contacts (no contact surfaces). I am trying to fix one end of this model and apply inertial load on the other.
However the heavy parts are penetrating into the soft ones. How do I avoid this model penetration?
Thanks,
I have problems with it too; if you find the answer, let me know. Typically if the parts are bonded, then i just unite them in UG, then import them as one single parasolid.
I figure the bonded contact can't be too (hoepfully) different than the element itself.
spider80 said:
Hi,
Thanks,
It sounds to me like the contact conditions aren't defined properly, or the penetrations aren't "real." Sometimes when you are displaying displacements using ANSYS Workbench, it will automatically scale the displacements being displayed so it's easy to see what's going on; however, this can make things look artificially deformed, especially when the diplacements are scaled up by a factor of 1000 or more.
I would like to see a screenshot of your geometry and where the penetrations is occurring, I suspect it can be solved by re-defining the contact conditions and taking a good look at your loading and boundary conditions.
I do believe in ANSYS you can control the amount of penetration between nodes and or surfaces. I will check on that.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
