Can infinite recurrence be mathematically proven?
The discussion centers on the concept of infinite recurrence in mathematics, particularly relating to the number zero. The original poster, a novice in math, questions whether infinite recurrence can be mathematically defined, especially in the context of zero, which is often considered undefined in certain operations like division. They ponder how zero can recur infinitely while remaining unchanged, suggesting that this could imply a form of complexity. The conversation hints at the relationship between infinite series and the recurrence of zero, inviting further exploration of these mathematical ideas. The topic raises intriguing philosophical and mathematical questions about the nature of infinity and definitions in mathematics.
Opoint
Hi, I would like to tell the room I’m a novice. I know very little math, mostly Algebra. So asking these questions in themselves are over my head. But I have a question that I wonder can be shown mathematically. I want to know if there can be an infinite recurrence. (For all I know it could be a little syntax or symbol) – denoting such an action.
This was my first post on this forum. Please elaborate if you know the answer.
Perhaps I wasn’t precise enough. You see, I’m seeking a number known as zero. And this quality is seen in math more than anywhere else. Perhaps this observation is best said in the philosophy room. But I’m going to give it a go in here instead (since I believe it COULD be represented mathematically) and this room is for math.
To continue my initial thought the ‘infinite recurrence’ Idea: largely this number is undefined. But so is dividing by 0: so the undefined is definable… as simply unsolvable.
Further, I have a thought in my mind regarding the number zero (perhaps only mathematical zero) –As it is related to recurrence. In other words, zero must recur an infinite amount of times and still remain 0 (in order for it to be defined as 0). But, at what point does recurrence make complexity? (This we may never know) If zero can indeed recur an infinite amount of times… it would then follow it was infinitely complex.
I know this is a big homework problem. But please try and respond to this.
Do you mean like in an infinite series?
\sum^{\infty}_{1} \frac{1}{x^2}
And with your infinite sum of zeros?
\sum^{\infty}_{1} 0
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
