MHB Infinite Geometric Series and Convergence
The discussion focuses on finding the common ratio for an infinite geometric series. For a series with an initial term of 4 that converges to a sum of 16/3, the common ratio is calculated as r = 1/4. Another series is analyzed, leading to a common ratio of r = √5/2, which is greater than 1. Since this ratio exceeds 1, the series diverges. The key takeaway is that a common ratio greater than or equal to 1 indicates divergence in infinite geometric series.
karush
MHB
a. Find the common ration $r$, for an infinite series
with an initial term $4$ that converges to a sum of $\displaystyle\frac{16}{3}$
$$\displaystyle S=\frac{a}{1-r} $$ so $\displaystyle\frac{16}{3}=\frac{4}{1-r}$ then $\displaystyle r=\frac{1}{4}$
b. Consider the infinite geometric series
$\displaystyle
\frac{8}{25} + \frac{4\sqrt{5}}{25}+\frac{2}{5}+\frac{\sqrt{5}}{5}+\cdot\cdot\cdot$
c. What is the exact value of the common ratio of the series
$\frac{8}{25}\cdot r = \frac{4\sqrt{5}}{25}$ so $r=\frac{\sqrt{5}}{2}$d. Does the series converge?
not sure how to do this?
Mathematics news on Phys.org
Hi karush,
Your final answer for part a is correct.
To find the common ratio, $r$, solve $\dfrac{16}{3}=\dfrac{4}{1-r}$ for $r$.
Please show your work.
Part d:
Is $\dfrac{\sqrt5}{2}$ greater than, less than or equal to $1$? What does your answer to this question imply?
$$\displaystyle S=\frac{a}{1-r} =$$
so $\displaystyle\frac{16}{3}=\frac{4}{1-r} \\
3\cdot4 = 16\left(1-r\right)\implies12=16-16r\implies4=16r\implies r=\frac{4}{16}=\frac{1}{4}$b. Consider the infinite geometric series
$\displaystyle
$\frac{\sqrt{5}}{2}=1.11$ $r\ge1$ no it divergess
$r>1$
Correct. :)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
