Info/help/cct diagrams on ECG machines
  • Thread starter Thread starter juming
    Diagrams Machines
Information on ECG machines and their operation is sought for creating a simple wireless ECG device using Bluetooth or RF technology. Resources like HowStuffWorks do not provide direct explanations but offer links to related sites, such as TheMDsite, which focuses on EKG interpretation rather than machine mechanics. A search for "EKG machine electrode circuit" yields valuable results, including a paper titled "A Portable, Low-Power, Wireless Two-Lead EKG System" from Harvard. These resources can assist in understanding the circuitry and functionality of ECG machines. Additional research may be necessary to gather comprehensive information on the subject.
juming
I'm looking for info/help/cct diagrams on ECG machines, how they work etc etc. the full works. Looking to make a "simple" wireless ecg on bluetooth/rf.
any help? sites? thanks:)
I went to Howstuffworks.com and did a search. They don't have a direct explanation about how EKG machines work, but they did have a link to this interesting site:
http://themdsite.com/default.cfm
That site is more about interpreting the EKG trace, not about how the machine measures it.
Then I googled ekg machine electrode circuit and got lots of good hits. Here's the first one:
http://www.eecs.harvard.edu/~mdw/papers/ekg-embs04.pdf
Hope that helps. -Mike-
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
