Initial and final states of hydrogen atom
vileoxidation
A hydrogen atom in an excited state emits a photon of wavelength 95nm. What are the initial and final states of the hydrogen atom? [Hint: you will need to make a reasonable guess of what is the final state. look at the energy of the photon and compare this energy with all the possible transitions in the hydrogen atom.]
En=-E0/n^2
lambda=hc/(Ei-Ef)
For the initial state, I set 95 = 1240/ (13.6-(-13.6/n^2)) and solved for n. I got 4.985, so I said it was 5th order initially. However, I think I may be doing this entirely wrong, as I cannot figure out how to get the final state.
The equation you solved is assuming the final state of the hydrogen atom was the ground state, n=1. Could the final state have been any other n?
Does that change my equation for finding the initial state, or just for the final state? And for the final state, I tried to find E with E=hc/lambda, and then plug that in as the final energy, but that didn't work. I got something less then one.
In general, the energy is 13.606*(1/nf^2-1/ni^2) where nf is the final state and ni is the intial state. What you did in your first attempt is basically the same as putting nf=1 and finding ni. And ni=5 looks good to me. Why couldn't nf be 2 or larger?
Okay, so what I did now was set 95 = 1240 / [(-13.6/n^2)-(-13.6/25)] and solved for n, but I am getting something between 1 and 2, and not really very definitively either one. You can't be between energy states, so I know I must still be doing something wrong.
Thank you for all your help so far!
Well, I get about 1.04 which is about as close as you can expect from the accuracy of everything else around.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
