Initial Velocity Question
To determine the initial velocity of a water balloon launched vertically without a stopwatch, the discussion emphasizes using the conservation of energy and equations of motion. Key equations include VFy^2 = VOy^2 + 2a*Displacement Y, where the final velocity (Vfy) is zero at the peak height. Participants discuss measuring displacement with a ruler or protractor, suggesting using trigonometry to calculate height based on angles and distances. The conversation highlights the importance of understanding the relationship between height and velocity, noting that velocity increases with the square root of height changes. Overall, the thread provides insights into applying physics principles to solve the problem effectively.
MaNiFeST
Ok So if I were to launch a waterballoon with a waterballoon launcher VERTICALLY , how could I find out the Initial Velocity With OUT a stop watch? My other supplies include a meter stick
Are you familiar with conservation of energy?
This is for a lab at school and you get Extra Credit if you can figure out the first part without a stop watch. Would i have to weigh it? And sorry, I am not familiar with conservation of energy
Ok, are you familiar with the equations of motion?
I am familiar with the equations for angles ( sin, cos), displacement in X,Y , etc,, for constant/non constant velocities and Trajectories
Look through them and try to find one that involves the parameters you think are going to be important and post it.
This isn't really a homework question but w/e
Thanks again
Well if I am shooting an object vertically then Displacment X will be 0m, and
Vy = Vo * sin(90) because the degrees will be 90
VFy = 0 m/s
Thats about all the variables i know atm
Im unsure of which equation to use
Well, don't solve any equations yet, just look for some that might be useful, and well work from there.
Would this work
VFy^2 = VOy^2 + 2a*Displacment Y
Aha, you are on to something. Keep going.
Displacment Y = {(Vo^2+sin(2*angle)} / g
Only other one i know that doesn't involve time
where did this come from? You were on the right track before. Maybe you should take a closer look at your first equation.
its equation for X or Y displacment
I am looking for Initial Velocity (Vo) and those two are the only ones that do not include time because i won't have a stop watch when doing this experiment
Yes, look at your first equation, and you tell me what each of those terms mean.
I am looking for Initial Velocity and not just VOy
Final Velocity of Y = is 0 m/s in this case
VOy^2 = is unknown
a = 9.81m/s^2 in this case
Displacment Y = is also unknown
Ok, we need to get this terminology straight.
V_{fy} means the final velocity in the y direction.
V_{oy} means the initial velocity in the y direction.
Does this help at all?
Yes, that's correct. Now when does this occur?
VFy That occurs when the object stops right before it comes back down
I Know what the terminology means,
How would a ruler be useful given this information? What is the value of Vfy?
Thats the thing, I have almost no idea
Well, you just said it yourself:
What does that mean?
It means that in the Y direction, the final velocity is 0 because there is no motion, it suspends in midair
Exacttttttly. So what does that mean Vfy =?
VFy = 0 m/s
Bingo. Now, think about that ruler. What could you do with that ruler now that you have this new information?
I can't measure the displacement of Y because it is too great, so I am really stumped
Why not? Use a really big ruler. Make tick marks on the wall with chalk spaced half a foot apart it comes to that. If the velocity is small, do you think the distance is going to be great?
Ooh i could gently launch it correct? nm , this wouldn't work , the force would be too low than when i launched it a second time
Sure, why not? You can launch it within reason. In fact, if you have a meter stick, calculate for me right now, what velocity it would need to reach 1 meter?
Let's see if it is resonable.
I wish i could, i would, but all the supplies are at the lab in school :(
  • #31
What supplies, you have an equation!
Write the equation down for me! We just took care of all the terms!
Come on now, you know this. You were the one that supplied me with all the information.
  • #32
0 = Voy^2 + 2(-9.81m/s^2)(1m)
19.62=Voy^2
4.429m/s=Voy
! I just made a = -9.81 for going up so wouldn't end up with negative answer
  • #33
Yes, that is correct, in this equation you must make the acceleration -9.81m/s, do you know why?
  • #34
So if the Voy is 4.429m for 1 m , then wouldn't it be different if the displacement was bigger? so how would i know how many times to multiply 4.429 by?
SO
4.429m/s = Vo * sin(90)
Vo = 4.429 m/s
  • #35
I must make a = -9.81 because it is going away and cannot have a negative velocity?
  • #36
Whoa, sir. Why are we back to introducing this equation?
We just used the only equation of importance here, namely: V_{f}^2=V_{0}^2+2a(ds)
  • #37
Yeah sorry, i forgot that sin(90) is 1 , so they are the same because it is going vertical anyway
  • #38
What is the effect of gravity on the balloon as it moves up?
  • #39
gravity is pulling it down to earth, but you can use it either way + or - , you just have to change it to - when the balloon comes back down
  • #40
It's not an 'either way', it depends on the physics of the situation. Is it going up? If it is, then gravity acts to slow it down and acceleration must be negative, or deceleration.
If its going down? Then gravity is acting to accelerate the body and it is positive.
This is not just a pick which way gives you the write answer.
  • #41
oh , well in my physics class atm we arnt dealing with deceleration, only one form of acceleration , but yeah i get what you mean
Thanks again
  • #42
It is the same thing, except there is a minus sign for deceleration.
  • #43
SO
Vo = 4.429 m/s
This is not correct, the change in initial velocty is not a linear change with stop height.
I.e., if it goes 1 meter and 4.429m/s, it will NOT go 2meters for 2*4.429m/s, because the velocity is squared:
V_f^2 = 2a(ds)
Plug in numbers for different heights, ds, and post your results.
Hint: Choose multiple values of change in ds, or height. I.e., like 1m, 2m, 3m,4m etc. etc. etc.
  • #44
5m = 9.9045
7m = 11.719
10m = 14.007
12m = 15.344
15m = 17.155
20m = 19.809
  • #45
Good, now compare 5 and 10 and 15 and 20. What do you notice?
  • #46
its about
1.12
2.25
3.38
4.51
  • #47
so, fix what you said earlier:
  • #48
Hmm i dunno, how would i measure a displacement going higher than 1m? i don't think i can exactly mark the walls :(
there must be a way
sorry lol i just really want that extra credit :)
  • #49
Do not worry about measuring it right now, I am trying to get you to learn about the physics. Fix that statement above.
Hint: Look at your ratio. Your height changed by a factor of 2 from 5 to 10 meters, how did your velocity change?
  • #50
ohhh
1.12*2 = 2.24
2.25*1.5 = 3.375
3.38*1.33 = 2.541
