vetenar
- 5
- 3
I am designing an inlet tube and a screened outlet for a cylindrical tank with a top opening hole (which determines the water level). I hope I could receive some suggestions and advice on the approach or some texts/equations I should check out. I am still in the process of learning fluid dynamics and have read about the basics (such as Bernoulli's principle).
The cylindrical tank (40 L) is for fish larval rearing:
- water flow rate ##\leq## 1 L/min, provided ##\leq## 10 hr/day
- outlet mesh ##\approx## 150 ##\mu m##, so that the food can flow out, but the larvae will not be damaged as they pass by. It should have enough surface area to avoid clotting and should be easy to take down for cleaning.
- one (or more) aeration line to generate circular motion of water. Aeration rate should be only big enough so that the larvae would spend more time in the middle of the tank (they are mostly carried by water current).
The difficulty is that it has to be able to wash all the food out within several hours.
I have tried several things already, but there are too many things to test at once. The shape and position of the screen outlet, the flow rate, the shape and position of the inlet tube, the position and rate of aeration. And so far the screen outlet remains the biggest problem; it either clots or could not wash the food out. I imagine this is also related to aeration and flow direction.
Any help is fully appreciated. Thanks very much in advance.
